Author Topic: Hook giving winning team points  (Read 6583 times)
Offline Zmaster
« on: July 29, 2014, 09:17:56 am »
I found a Deathrun gamemode on Facepunch and I want to make a script that gives every player on the winning team of a round a certain amount of points for PointShop
I have the hook ready, I'm just not sure how to give the points to everyone on the team
Here's the function for giving points ply:PS_GivePoints(10)
And here's what I have so far
if SERVER then
AddCSLuaFile() -- Send the file to the client.
hook.Add( "OnRoundSet", "DR Money", function( round, winner )
if round == ROUND_ENDING then
end )
I would imagine that winner:PS_GivePoints(10) wouldn't work since winner would be a team and not the players on the team
Re: Hook giving winning team points
« Reply #1 on: July 29, 2014, 10:18:41 am »
OnRoundSet is a serverside hook. No need to do "AddCSLuaFile".
You could loop through players table using a "for" loop (with "player.GetAll()"), and then check if ply:Team() is the same as the "winner"-team.
Then after that, you can give the points using Player:PS_GivePoints(10).
I have the code ready which should work (I haven't played or done any deathrun stuff, so I'm not 100% sure), but if you'd like to give it a go yourself then you should try to use some of my tips (hope I didn't forget anything).
The code can be found here if you aren't able to do it yourself (I couldn't hide it in a spoiler or anything).
Offline Zmaster
« Reply #2 on: July 29, 2014, 10:25:45 am »
Okay I'll try to figure it out using the info you gave me, thanks!
Offline Zmaster
« Reply #3 on: July 29, 2014, 11:02:07 am »
Alright, here's the code I ended up using (thanks to Decicus)
if SERVER then
                        for _, ply in ipairs( player.GetAll() ) do
                                if ply:Team() == winner then
                                        ply:PS_GivePoints( 25 )
if winner == TEAM_DEATH then
for k, ply in pairs( player.GetAll() ) do
ply:ChatPrint( "The Death team has been given 25 points for winning!" )
ply:ChatPrint( "The Runner team has been given 25 points for winning!" )
        end )
And it works fine
However, when the round ends and it puts one of those messages in chat, it'll usually put it in twice (and sometimes three times) instead of just once
How would I make it put in that message only once?
Edit: The code shown in this post isn't making "The 2 team" anymore, that screenshot was made before I changed it to say Runner or Death
« Last Edit: July 29, 2014, 11:08:22 am by Zmaster »
« Reply #4 on: July 29, 2014, 11:22:19 am »
You included your if/else statement inside the first for loop. Thus it printed to everyone, then looped again to print another time.
It's a bit difficult to explain, so I'll just do this:
if SERVER then
                                -- Your print code is here.
                        -- It should be here
        end )
Also, I don't know if it was just the code tags, but you should probably work on your tabs/spaces for each line. The chatprinting code was a bit hard to read for me without putting it into Notepad++.
Offline Cobalt
« Reply #5 on: July 29, 2014, 11:36:27 am »
Completed code with the chat print added. Use team.GetName to get the name of the team from the index.
if SERVER then
for k, v in next, player.GetAll() do
if not v:Team() == winner then
continue
v:PS_GivePoints( 25 )
local name = team.GetName( winner )
PrintMessage( HUD_PRINTTALK, "Players on the " .. name .. " team were given 25 points for winning."
end )
Offline Zmaster
« Reply #6 on: July 29, 2014, 11:46:10 am »
You were missing a ) on line 11, Cobalt, but thanks to both of you :P
