Author Topic: ULX Unknown Revision?  (Read 4831 times)
Offline Sophersky
  • Fire doesn't destroy, it cleanses.
« on: August 03, 2014, 08:21:30 am »
Small problem, whenever the server runs the advert saying what the ULX version is, it'll say:
This server is running ULX Admin Mod version <SVN> unknown revision by Team Ulysses -- ulyssesmod.net
SVN links I'm using:
https://github.com/Nayruden/Ulysses.git/trunk/ulib
https://github.com/Nayruden/Ulysses.git/trunk/ulx
Anyone know how to fix this?
"Citizen notice. Failure to co-operate will result in permanent off-world relocation." ~ Overwatch
Re: ULX Unknown Revision?
« Reply #1 on: August 03, 2014, 01:31:54 pm »
The revision numbers used to be pulled directly from the SVN repositories if it detected SVN was in use. Unfortunately, a change in gmod (or SVN, can't remember) made that break, and we might not be able to access that anymore. Don't worry though, if you're constantly updating from those SVN links, you should be running the latest version. :)
Offline Sophersky
« Reply #2 on: August 03, 2014, 02:37:46 pm »
Oh, I saw it saying the revision number on other servers and thought I was doing something wrong. Thanks!
