Author Topic: ULX not keeping rank  (Read 3786 times)
Offline Gabe Newell
« on: August 12, 2014, 04:13:26 am »
hey, i just bought NFO servers and i installed with their tool. i have no other addon. i make myself superadmin and its fine. when i leave and join back im not superadmin anymore. heres the error in console
  1. Lua Error: [ERROR] gamemodes/darkrp/gamemode/modules/fpp/pp/server/ownability.lua:466: attempt to call method 'CPPIGetOwner' (a nil value) 1. fn - gamemodes/darkrp/gamemode/modules/fpp/pp/server/ownability.lua:466 2. unknown - addons/ulib/lua/ulib/shared/hook.lua:183
Offline Goddess
  • EnviousRP Admin Advisor
    • Envious Roleplay
Re: ULX not keeping rank
« Reply #1 on: August 13, 2014, 09:58:10 pm »
If you are making yourself super admin in ulx, you should most likely make yourself super admin in the fadmin scoreboard as well.
If that doesn't work, and you have tried everything in the ULX Menu, I suggest using R-Con commands at that point. Just also note that some R-Con commands are blocked, but I am pretty sure you can do it. You can also do this command:
ulx adduser <user> or <steamid> or <userid> <rank> 999
That may help your situation, if not, then use R-Con, all you need to be is the owner, and you need to know your servers R-Con password, whatever you set it to.
Want to know more? Check out my Steam! I will be happy to accept you!
If you want even more! Check out the server I play on! Envious RolePlay!
« Reply #2 on: August 14, 2014, 12:43:35 am »
I'd also make sure you have our latest code from Github.
Many years ago, nfo server tool weren't keeping our code up to date.
It's possible the same is happening.
We actually prefer you disable fadmin...we've seen too many conflicts.
Owner is a made up group that most scripts don't see as higher than superadmin, even with our attempts to tell other scripts when inheriting superadmin.
Offline Goddess
    • Envious Roleplay
« Reply #3 on: August 14, 2014, 01:16:44 am »
Exactly what he said, though, I do admit fadmin does have a few bugs, and some people have used it for malicious benefits.
Your best option could be to disable fadmin, but that's only my opinion. You can keep it, since not many can really exploit fadmin.
I was gonna use my own API for stuff like this, but I don't have my own server at the moment.
