Author Topic: Have a Gamemode Detect a ULX function?  (Read 6399 times)
Offline Zombine
« on: August 15, 2014, 03:52:02 pm »
Like the title says. Say I'm in DarkRP, and I'd like the gamemode to run a certain feature if the user is cloaked.
Specifically, if the user is cloaked, it will hide the name and job tag above their head.
Is this at all possible?
I have some code someone gave me to hide the tags if the player is using a certain job, but I'm unsure if it can be made to interact with ULX.
hook.Add("HUDShouldDraw","DarkRP_HideJobsEntityDisplay",function(hudName)
   if hudName ~="DarkRP_EntityDisplay"thenreturnend
   local playersToDraw ={}
   for _,ply inpairs(player.GetAll())do
       if ply:Team()~= TEAM_SOMEJOB then
           table.insert(playersToDraw, ply)
   returntrue, playersToDraw
end)
Offline bender180
    • Benders Villa
Re: Have a Gamemode Detect a ULX function?
« Reply #1 on: August 15, 2014, 04:11:21 pm »
You would have to modify the existing cloak command or write one yourself.
Offline Zombine
« Reply #2 on: August 15, 2014, 04:12:38 pm »
All right, I suppose I'll try that.
« Reply #3 on: August 15, 2014, 07:52:56 pm »
Nah, you don't.
You could use ULibCommandCalled or perhaps ULibPostTranslatedCommand to look for "ulx cloak" and run any function/code needed.
Offline Zombine
« Reply #4 on: August 16, 2014, 11:54:40 am »
So then do you suppose I might be able to sneak this in there to have it run the rest of the code?
if ply:ULibCommandCalled( ply, ULib.invisible ) ~= true
I'm about 99.99% sure that won't work, because I am terrible with lua, but thank you anyway JamminR. I'll go experiment.
Offline Cobalt
« Reply #5 on: August 16, 2014, 01:15:58 pm »
if ply:GetMaterial() == "models/effects/vol_light001" then ...
Offline Zombine
« Reply #6 on: August 16, 2014, 04:03:49 pm »
Thanks. So this is what it looks like now.
  1. hook.Add("HUDShouldDraw", "DarkRP_HideJobsEntityDisplay", function(hudName)
  2.     if hudName ~= "DarkRP_EntityDisplay" then return end
  3.
  4.     local playersToDraw = {}
  5.     for _,ply in pairs(player.GetAll()) do
  6.         ply:GetMaterial() == "models/effects/vol_light001" then
  7.             table.insert(playersToDraw, ply)
  8.         end
  9.     end
  10.     return true, playersToDraw
  11. end)
I'm assuming that this wouldn't resume drawing their nametag if their material is no longer vol_light, so I added an else statement. Does it look correct?
  3.
  8.         end
  9.     else
  10.             table.remove(playersToDraw, ply)
  11.         end
  12.     end
  13.     return true, playersToDraw
  14. end)
