Author Topic: How to get rid of _Uncategorized?  (Read 4320 times)
Offline Valgoid
  • Wanna Be Lua King
« on: August 16, 2014, 11:47:02 am »
I had added some addons in the past, when i removed them the old commands went into the _Uncategorized section. How do I remove this?
Offline Storm
Re: How to get rid of _Uncategorized?
« Reply #1 on: August 17, 2014, 10:20:46 am »
Great question! I have wondered the same thing!
« Reply #2 on: August 19, 2014, 10:20:32 am »
Hmm, do no commands show up under "_Uncategorized"?
The two things you'll want to do is check your groups.txt/users.txt file to see if there are any remaining references to the commands that have been removed. Secondly, there is a file in the ULX data folder called misc_registered.txt which may store references to the removed commands as well- If you don't want to edit it manually, I *think* you should be safe to delete it, but each command may give itself access to its respective default group.
Offline Valgoid
  • Wanna Be Lua King
« Reply #3 on: August 20, 2014, 09:47:03 pm »
I could not find any of those you listed above and yes the old commands do show up under the _Uncategorized
« Reply #4 on: August 20, 2014, 09:51:15 pm »
groups/users and misc_registered would be in server gmod/data/ulib folders.
Not ULX like Stickly mentioned.
