Author Topic: Adding models from different games?  (Read 6777 times)
Offline Sophersky
  • Fire doesn't destroy, it cleanses.
« on: August 17, 2014, 11:00:28 am »
I was wondering if there was a way to import a model from, say, TF2, into Gmod and use it in Pointshop. Is this possible?
"Citizen notice. Failure to co-operate will result in permanent off-world relocation." ~ Overwatch
Offline UnderYouFive
Re: Adding models from different games?
« Reply #1 on: August 17, 2014, 11:40:42 am »
Yes it is, you need to find an addon like this http://steamcommunity.com/sharedfiles/filedetails/?id=292523019&searchtext=tf2+player+model then you need this code.
ITEM.Name = 'You name here'
ITEM.Price = 250
ITEM.Model = 'models/player/Yourmodelnamehere.mdl'
function ITEM:CanPlayerEquip(ply)
    return ply:Team() ~= TEAM_UNDEAD
function ITEM:OnEquip(ply, modifications)
if not ply._OldModel then
ply._OldModel = ply:GetModel()
timer.Simple(1, function() ply:SetModel(self.Model) end)
function ITEM:OnHolster(ply)
if ply._OldModel then
ply:SetModel(ply._OldModel)
function ITEM:PlayerSetModel(ply)
Offline Sophersky
« Reply #2 on: August 17, 2014, 11:55:33 am »
I mean is it possible to extract a model like tf2_misc_dir.vpk/models/lilchewchew/lilchewchew.mdl and allow pointshop to use it?
« Last Edit: August 17, 2014, 12:00:12 pm by Sophersky »
Offline Neku
« Reply #3 on: August 17, 2014, 12:05:35 pm »
I don't know how TF2 handles their models, but it looks to be the same as HL2.
Go ahead and give it a shot.
« Reply #4 on: August 17, 2014, 12:08:31 pm »
I'm pretty sure that if you have Team Fortress 2 mounted on a Gmod server, then you can use it as a normal "models/tf2_model_directory/modelname.mdl" in the pointshop, although I have no experience myself with a pointshop.
Offline Sophersky
« Reply #5 on: August 17, 2014, 12:13:49 pm »
So something like models/lilchewchew/lilchewchew.mdl would work?
« Reply #6 on: August 17, 2014, 12:19:18 pm »
If it's mounted and the directory from the root dir (TF2/GMod) would be that, then yes, that should in theory work.
Offline Sophersky
« Reply #7 on: August 17, 2014, 01:03:06 pm »
So the tf2 folder has to be located in the same file where the gmod vpks are?
Edit: This worked, thanks!
« Last Edit: August 17, 2014, 02:02:40 pm by Sophersky »
