Author Topic: Wont let me admin  (Read 14667 times)
Offline Dirtyhand
Wont let me admin
« on: December 24, 2005, 08:49:45 pm »
When I make a listen server it wont let me be admin and I tried adding my steam id to ulx_users.lua and I added to the bottom addUser( "STEAM_0:0:4371726", "abcdefghijklmnopqstuz" ) and it still wont work. Have any idea why? ???
Re: Wont let me admin
« Reply #1 on: December 24, 2005, 08:58:50 pm »
Are you running the listen server fix, or are you the player running the listen server?
Offline Dirtyhand
« Reply #2 on: December 25, 2005, 09:20:36 am »
Im using  a listen server fix cause it wont let me make one without it.
Offline Mank
    • Ulysses Mod!
« Reply #3 on: December 25, 2005, 02:09:38 pm »
You don't need to put your own Steam ID in to users.lua.  Anyway, considering you're using the fix it won't work anyway because of listen server fix stopping Steam ID's  (If I remember correctly).
Offline Dirtyhand
« Reply #4 on: December 25, 2005, 05:12:52 pm »
ok thanks
Offline dragster112
« Reply #5 on: January 16, 2006, 04:32:10 pm »
wat does it mean by listen fix??
i start a lan sever and i cant do admin stuff my ulx_users.lua file says all the normal stuff but i put my steamid in like this
addUser ( STEAM_0:0:455045 bcdefghijklmnopqrstuz )
is that wright? ???
« Last Edit: January 16, 2006, 05:05:29 pm by dragster112 »
i rock woohooo
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
« Reply #6 on: January 17, 2006, 01:13:46 pm »
LISTEN_ADMIN_ACCESS      =   "bcdefghijklmnopqrstuz"
Put that in there
Offline dragster112
« Reply #7 on: January 18, 2006, 09:50:38 pm »
Do you need to type a command in console? like ulx_addUser D@_G0LD3N_MEDALION FULL or not?
p.s the full is for the acsess thing
please reply
« Last Edit: January 19, 2006, 07:36:33 pm by dragster112 »
i rock woohooo
    • BlueFire
« Reply #8 on: January 20, 2006, 09:34:22 am »
edit ulx_users.lua in gmod9/lua/ulx
Offline dragster112
« Reply #9 on: January 20, 2006, 04:59:23 pm »
edit wat?
Answer Me
« Last Edit: January 27, 2006, 09:24:03 pm by dragster112 »
i rock woohooo
    • BlueFire
« Reply #10 on: January 27, 2006, 11:18:34 pm »
the file in the folder at gmod9/lua/ulx
Offline kiwibird2
« Reply #11 on: February 04, 2006, 09:59:59 pm »
Ok, so I am running a Listenserver fix right now, and when i use ULX i cannot be admin by putting my steam id in ulx_users. Also i tried not putting it in there and it still wont work. also LISTEN_ADMIN_ACCESS      =   "bcdefghijklmnopqrstuz"  is in there but still. Help please? should i getr ris of the server fix? but then whats the ponit of having this ULX?
