Votemap.txt
Topic: Votemap.txt (Read 3838 times)
M21z
Votemap.txt
September 05, 2014, 02:49:43 pm »
I need some help setting this up, I have been trying to find tutorials and examples of how to actually set this up but cant find any. My server has been adding random maps to its rotation, for example de_nuke and other de_ maps. I dont mind those maps just when it loads some of these maps of the server it crashes and I cant get on the server unless I reset the command line to be on a different map. Help would be appreciated. Thanks
Caustic Soda-Senpai
Sr. Member
<Insert something clever here>
Re: Votemap.txt
September 05, 2014, 10:08:35 pm »
Do you have CS:S Mounted?
Avoid
Full Member
Re: Votemap.txt
Reply #2 on:
September 10, 2014, 09:41:23 am »
Hello,
you can simply remove certain maps from the rotation, by using Xgui.
Settings -> Ulx Mapvoting -> There you will be able to add/remove maps from the rotation.
Also check your mount.cfg for mounted game content, like CS:S.
Votemap.txt
