Author Topic: ULX Losing Rank After Leave  (Read 3793 times)
Offline pigeontroll
« on: September 10, 2014, 06:10:09 pm »
Hello, I am an admin of a DarkRP server that has ULX and FAdmin, but if a player with a rank leaves, he loses his rank. Is there a way to fix this? BTW I don't have access to the server files, but I'm going to message the manager if it will work.
If you can't fix it, could you also make it so that when a player joins, it checks their STEAM_ID/name to see if it fits (like you right it out on a lua file), and then if it does, give them the rank?
Re: ULX Losing Rank After Leave
« Reply #1 on: September 10, 2014, 06:33:14 pm »
Known conflict, mentioned 10s if not 100s of times within our forum (and usually easily found using our search)
Remove FAdmin.. it fights group control.
As for your question...we already store all group users in a file and check when they join.
But again, known conflict.
Offline pigeontroll
« Reply #2 on: September 10, 2014, 06:55:26 pm »
Do you think you can make it so that ULX overrides FAdmin so the server can still have both ULX and FAdmin or FAdmin lets ULX override it?
