Author Topic: Want a rank with No mic/talk Privalleges!  (Read 6366 times)
Offline awesomenessispure
« on: September 13, 2014, 11:52:10 am »
How do i make a class where i can restrict mic! I want a class where i can add all the Annoying spammers and Squeakers to!
« Last Edit: September 13, 2014, 12:28:56 pm by awesomenessispure »
Offline Avoid
Re: Want a rank with No mic/talk Privalleges!
« Reply #1 on: September 13, 2014, 12:23:48 pm »
Hello,
this does not belong here, would probably be better to move it into the developers discussion.
Take a look at this.
Also, thank you for detailed explanation!
« Reply #2 on: September 13, 2014, 12:28:13 pm »
How do i move this!
Offline Matryan
« Reply #3 on: September 20, 2014, 09:04:35 am »
When you say class, I'm assuming you mean ULX group/rank.
this should work, chuck it in lua/autorun.
hook.Add("PlayerCanHearPlayersVoice", "stopannoyingmicspammersandsqueakers", function(listener, talker)
     if ( talker:GetUserGroup() == "RANK" ) then
          return false
          return true
Whilst in game, create a new rank in ULX, call it what ever you want.
Then rename RANK in the code to that new ULX rank.
This may work.
EDIT:
Oops. forgot parentheses
« Last Edit: September 21, 2014, 05:35:36 am by Matryan »
« Reply #4 on: September 20, 2014, 01:20:51 pm »
     if ( talker:GetUserGroup == "RANK" ) then
          return false
          return true
This should work.
This would just throw an error. You would need to change the third line to:
or you could use IsUserGroup instead:
if ( talker:IsUserGroup( "RANK" ) ) then
