Author Topic: ULX Motd Broken  (Read 12685 times)
Offline PAL-18
ULX Motd Broken
« on: September 16, 2014, 09:34:38 pm »
I'm using a recent SVN (downloaded 1 week ago) and the motd doesnt work.  It isnt appearing on connection to the server.
Here's what i have for my settings:
ulx showMotd 1
motdfile motd.ftwgamer.com/cr-rules.php
Did a Gmod update break something or is the svn broken?
Offline Caustic Soda-Senpai
    • Steam Page
Re: ULX Motd Broken
« Reply #1 on: September 16, 2014, 10:15:39 pm »
try http://motdfile motd.ftwgamer.com/cr-rules.php
Offline Neku
Re: ULX Motd Broken
« Reply #2 on: September 16, 2014, 11:10:45 pm »
That's not a complete URL.
Use http://motd.ftwgamer.com/cr-rules.php
EDIT:
3) NO sick/nude sprays - keep them PG-13.
darn
Offline PAL-18
Re: ULX Motd Broken
« Reply #3 on: September 16, 2014, 11:43:33 pm »
I tried that the first time and it didn't work either :S
Re: ULX Motd Broken
« Reply #4 on: September 16, 2014, 11:52:20 pm »
Define "not working"
Not opening for players?
Errors in server/player console? (Both?)
Tried placing your url in quotes? (Shouldn't have to do this, but who knows"
And yes, using full http is recommended.
motdfile "http://motd.ftwgamer.com/cr-rules.php"
EDIT. Corrected httpd:// to http://
« Last Edit: September 17, 2014, 07:23:37 am by JamminR »
Offline PAL-18
Re: ULX Motd Broken
« Reply #5 on: September 17, 2014, 12:28:29 am »
No lua errors, motd window doesn't show up at all.
Oddly, in the startup log, motdmenu.lua isnt loading.
//  shared/hook.lua          //
//  sh_base.lua              //
//  MODULE: sourcebans_config.lua//
ServerLog: [09/17/14 03:25:57][SourceBans.lua] Starting the database.
//  MODULE: uteam.lua        //
//  MODULE: xgui_server.lua  //
// ULX GUI -- by Stickly Man //
// Adding Main Modules..     //
//  bans.lua                 //
//  commands.lua             //
//  groups.lua               //
//  maps.lua                 //
//  settings.lua             //
// Adding Setting Modules..  //
//  client.lua               //
//  server.lua               //
// Adding Gamemode Modules.. //
//  sandbox.lua              //
// Loading Server Modules..  //
//  sv_bans.lua              //
//  sv_groups.lua            //
//  sv_maps.lua              //
//  sv_sandbox.lua           //
//  sv_settings.lua          //
// XGUI modules added!       //
//  MODULE: aafk.lua         //
//  MODULE: rocket.lua       //
//  MODULE: wordlist_kicker.lua//
//  MODULE: youtube_music_player_sh.lua//
ulx/songplayer_videos.txt
checking if exists
READING
    • Steam Page
Re: ULX Motd Broken
« Reply #6 on: September 17, 2014, 05:14:23 am »
EDIT:darn
oops I copy/pasted XD
    • Steam Page
Re: ULX Motd Broken
« Reply #7 on: September 17, 2014, 05:16:59 am »
Did you set the motd page through xgui or through the files?
Offline PAL-18
Re: ULX Motd Broken
« Reply #8 on: September 17, 2014, 09:06:05 pm »
Through the file.  When i try setting through xgui i get permission denied error (despite having access to all commands).
    • Steam Page
Re: ULX Motd Broken
« Reply #9 on: September 17, 2014, 11:45:37 pm »
humour me and post a snapshot of the xgui menu's motd setting, make sure you're superadmin.
Offline PAL-18
Re: ULX Motd Broken
« Reply #10 on: September 18, 2014, 12:35:55 am »
In case its my html that's messing up the motd, i reverted to the default ulx motd.  It's still not showing up.  My usergroup does have "ulx motd" permission and the ulx_motd.txt is in the data folder of server.
http://steamcommunity.com/sharedfiles/filedetails/?id=315448171
I even tried running server in sandbox mode in case the gamemode is breaking the motd somehow.
« Last Edit: September 18, 2014, 12:42:12 am by PAL-18 »
    • Steam Page
Re: ULX Motd Broken
« Reply #11 on: September 18, 2014, 02:58:14 am »
Ok, in the xgui, go to groups>superadmin (assuming you're superadmin) Click Manage Permissions and go to Cmds-Menus. Make sure the check box IS infact checked. If it is solid green instead of the faded green, go to groups>user and enable it the same way.
Next, go to the MOTD Settings in Settings>Server>ULX General Settings. MAKE SURE the Second check box is selected, the first one is optional. Type in your MOTD URL: http://motd.ftwgamer.com/cr-rules.php into the box.
Finally, proceed to type "!motd" in the chat or type "ulx motd" in console or of course, navigate to motd through !menu
And as you can see on my screen, it works just fine.
« Last Edit: September 18, 2014, 02:59:48 am by Archang3L »
Offline Neku
Re: ULX Motd Broken
« Reply #12 on: September 18, 2014, 07:55:47 am »
I personally think that page is better as a loading screen, rather than an motd.
Offline PAL-18
Re: ULX Motd Broken
« Reply #13 on: September 18, 2014, 01:00:19 pm »
ulx_motd is selected for my superadmin group (inherted from user group), but when i try to change the URL, im given the following error:
You do not have access to this cvar (ulx_showmotd), *FTW* PAL-18.
My loading screen is even better, a random logo displays with a random funny gif (one of a few hundred) with a changing funny one liner.  Most of the time, when people come in-game they discuss the funny weird thing they saw.  Here's what it looks like: http://motd.ftwgamer.com/gmod-load.php (copy/paste url into browser url bar, clicking it will display error).
« Last Edit: September 18, 2014, 01:02:22 pm by PAL-18 »
    • Steam Page
Re: ULX Motd Broken
« Reply #14 on: September 18, 2014, 08:17:38 pm »
Do you have the latest ULX? If so, try reinstalling a fresh copy.
