Author Topic: Calling a commands function from another addon  (Read 5676 times)
Offline kulcris
« on: September 29, 2014, 03:06:40 pm »
I'm currently coding some RTD results and I'm trying to call a command (that i added to ulx) from this other file. how would i go about calling .... For example the ulx.slap function without running a console command. and if that is not possible then how would i call the console command and use it on a player?
(sorry nub at coding)
RESULT.Name = "run"
run2b = math.random(.5,2)
runtime = math.random(15,60)
function RESULT:Trigger(ply)
ulx.sprintspeed(ply,run2b*240)
ulx.walkspeed(ply,run2b*220)
timer.Simple(runtime, function()
if (ply and ply:IsValid()) then
ulx.sprintspeed(ply,240)
ulx.walkspeed(ply,220)
ply:ChatPrint("Returned to normal speed.")
RTD:SendColoredChatMessage(ply, "Has returned to their normal speed.")
end)
function RESULT:ShowMessage(ply)
RTD:BroadcastMessageAboutPlayer(ply, "has been sped up / slowed down by", Color(0, 255, 0), run2b, color_white, " for ", Color(0, 255, 0), runtime, color_white," Seconds ", Color(0, 255, 0))
Offline kulcris
Re: Calling a commands function from another addon
« Reply #1 on: September 29, 2014, 03:27:37 pm »
RESULT.Name = "run"
run2b = math.random(2,10)
local plyname = ply:GetName( )
RunConsoleCommand("ulx", "sprintspeed", plyname, run2b*240)
RunConsoleCommand("ulx", "walkspeed", plyname, run2b*220)
RunConsoleCommand("ulx", "sprintspeed", plyname, 240)
RunConsoleCommand("ulx", "walkspeed", plyname, 220)
end)
This seems to have worked the way i would like it to.
Offline kulcris
« Reply #2 on: October 02, 2014, 02:08:20 pm »
I moved this into the trigger function so that it runs everytime it is triggered instead of just once the entire up time of the server
Offline bender180
    • Benders Villa
« Reply #3 on: October 02, 2014, 04:13:47 pm »
Not sure if this really answers what your asking but you could just use ulib functions instead of running ulx commands.
Heres the ulib Doc on slap seen as that is the example you used
and here is the full docs
edit: just read your code and i dont think this will really help you at all, sorry.
« Last Edit: October 02, 2014, 04:17:35 pm by bender180 »
« Reply #4 on: October 14, 2014, 10:44:10 am »
You might be able to access a reference to the function by checking the ULib.cmds.translatedCmds["ulx slap"] table- I'm pretty sure you can find one there.
Offline kulcris
« Reply #5 on: December 28, 2014, 11:37:04 am »
Sorry for the super late responses sometimes i get something in my head and then forget about it before i can get home and fully tinker with it XD Thank you for responding guys.
As for getting this to work i just needed to run the commands. it may be a bit messy but it seems to have worked
