Author Topic: ULX Setting keep resetting  (Read 8436 times)
Offline roblozs
« on: October 07, 2014, 05:33:15 am »
Okay so I have spent Day's trying to fix this but For some reason after a restart ULX Turns Godmode back on and pvp off and put's all setting to 250 I have tried to reinstall several times but no fix
Screenshot of settings
http://i.imgur.com/KdjSl7G.png
Server Log
http://pastebin.com/b0QKtt2D
Offline Neku
Re: ULX Setting keep resetting
« Reply #1 on: October 07, 2014, 07:46:52 am »
ULX does not control gamemode settings.
Offline Zmaster
« Reply #2 on: October 07, 2014, 07:47:19 am »
Just turn off god mode and turn on pvp via server.cfg
That way it'll always be the way you like when the server starts
« Reply #3 on: October 07, 2014, 09:08:32 am »
Correction and clarification -
ULX doesn't "save" settings changes like that because we can't edit server.cfg where those settings are supposed to be configured on server start.
Yes, we have a control panel to make it easier for quick switches, but ULX never saved those.
It's not a bug, nothing to fix.
Offline roblozs
« Reply #4 on: October 07, 2014, 01:03:17 pm »
okay dont you think nI have thoese setting set in my config http://i.imgur.com/mALOY67.png there you go but after every restart ULX has Godmod on and pvp off.
« Reply #5 on: October 07, 2014, 01:52:54 pm »
Roblozs, we're trying to explain, it's not ULX setting them.
ULX (Xgui in this case) simply looks at what's already set in memory, then displays it or allows temporary change of it until next server restart.
You likely already have another cfg, gamemode or addon setting those two convars to opposite what you want.
Check your server.cfg for duplicates? I've done that before. Have same one twice.
Did you actually edit the server file, and not your local client? I've done that before too.
Offline roblozs
« Reply #6 on: October 07, 2014, 01:54:29 pm »
Yes I edited the server config, and none of my addons edit thoese settings.
« Reply #7 on: October 07, 2014, 02:04:44 pm »
none of my addons edit those settings.
The ULX addon doesn't edit them on startup either.
Are you starting in Sandbox gamemode? It's possible DarkRP is doing some 'safe' rp setting or something somewhere.
If you shut down server, remove ULX temporarily, start server back up, Godmode should still be on, and PVP should still be off.
ULX doesn't change any godmode or pvp settings on startup of the server.
Offline roblozs
« Reply #8 on: October 07, 2014, 02:13:16 pm »
It's Dark RP, and you were right but idk witch addon it could be.
