Author Topic: ULX group prop cleanup times  (Read 5940 times)
Offline eliman
« on: October 19, 2014, 06:23:45 pm »
So basically the plugin/addon is simple, each rank has a different set time that their props will get cleaned up after disconnecting from the server, below will be an example of what i'm talking about.
Example:
Users - Prop cleans up in <x> minutes
Donors - Prop cleans up in <x> minutes
Admins - Prop cleans up in <x> minutes
etc..
Re: ULX group prop cleanup times
« Reply #1 on: October 19, 2014, 07:18:36 pm »
I thought UPS already did this.
To my knowledge, even if UPS doesn't, several prop protection scripts already do this, or at least, did.
Falco's comes to mind. No idea if Falco's is kept up to date, as it's been 5+ years since I last used it.
Good idea for a Sandbox ULib release if there aren't any, but, as ULib already controls group access, not really, imo, an additional part to be included in ULX by default.
We try to remain gamemode agnostic.
Offline eliman
« Reply #2 on: October 19, 2014, 07:56:28 pm »
Thanks for reply i'll take a look at both those addons and see if they meet my needs, never seen/used UPS before but i'm pretty sure Falco's doesn't come with group based clean ups (used Falco's near the first update release of Gmod13).
EDIT: Yeah, so basically i'm trying to get UPS working with GMod Stranded, but since Stranded already has its own PP system integrated with the gamemode... both UPS and the PP that comes with the gamemode don't really want to cooperate with each other.
« Last Edit: October 22, 2014, 08:45:11 pm by eliman »
