Author Topic: [Solved]Cant not edit groups [DarkRP] - ULX Addon WorkShop EXPLOIT found  (Read 8931 times)
Offline HENK
Hello,
I have ULX installed on my darkrp server (Yeah i know DarkRP is not made for RP this has been told me once by a dev)
but i know it should work with it as i played servers where ULX just worked fine but
i cant edit groups on my system Neither
I tried removing & reinstalling
I tried removing data
I tried disabling FAdmin
And its spamming my console with:
http://puu.sh/cp0xC/d2e9ad7096.png
http://steamcommunity.com/sharedfiles/filedetails/?id=331166550
« Last Edit: October 25, 2014, 07:34:56 am by JamminR »
Re: Cant not edit groups [DarkRP]
« Reply #1 on: October 24, 2014, 03:53:09 pm »
You have an exploit somewhere on your server.
Search our forum for that steam id and you'll see several mentions of the issue.
It's a timer the exploiter set up to remove them from bans in case they join your server, cause trouble, and get banned.
I don't remember if anyone here has posted what installed the exploit once they found/removed it.
As for group control, it might be due to the exploit, or the fact you're not setting yourself as superadmin correctly.
Once you've figured out the exploit issues, make sure you've seen our FAQ section for 2-3 articles regarding access.
Offline HENK
« Reply #2 on: October 25, 2014, 05:11:55 am »
I Think i've found the little basterd its hidden
http://puu.sh/cpRn1/c0dd46df21.png
Tip for everyone with this problem
1. Move all your addons exept ULX/ULIB & Darkrpmodification to another folder [On your computer or server]
2. Remove the Workshop collection id from the command line
3. Restart the server & join look if its spamming it
4. If it is its in DarkRP modification or the ULX/ULIB [Download them from this website ;D]
5. If not add back the workshop
6. Restart the server & join look if its spamming again
7. If it is! Good luck with extracting all the .gma files to find the problem
8. If not then check all your addons from the addon folder try to open every .lua file and press CTRL + F and type in the steamid [http://puu.sh/cpRGr/80a5a851a8.png] [i use Sublime text 2]
9. Once you've found the little basterd [should look similair to http://puu.sh/cpRn1/c0dd46df21.png] Remove that but keep looking for more exploits
10. Look out with what kind of addons you use from the workshop & Scriptfodder/Coderhire/the internet ;D
Re: [Solved]Cant not edit groups [DarkRP]
« Reply #3 on: October 25, 2014, 05:41:36 am »
Henk, mind notifying us of which addon/workshop release it was that had that?
Offline HENK
« Reply #4 on: October 25, 2014, 07:21:26 am »
For me it was CostumCommands
But i was so stupid to not get it from the original post -,-
so its was sord of my fault
Re: [Solved]Cant not edit groups [DarkRP] - ULX Addon WorkShop EXPLOIT found
« Reply #5 on: October 25, 2014, 07:36:28 am »
Indeed. Always get content from original release locations, and only if trusted.
Please PM me the URL of the workshop addon. (Or was it workshop? - if not workshop, where did you get it?)
Offline HENK
« Reply #6 on: October 25, 2014, 08:55:15 am »
It wasnt from the workshop but i cant find where i got it from anymore :(
it was Quite a while ago when i downloaded it! sorry :((((((((((((((((((((((((((((((((((((((((((((((((((((((((((
But i will keep looking for a moment You'll hear from me when i found it
Edit: But what i do know the person is called Chewgum: http://steamcommunity.com/id/Chewgumm/
Offline casey d
« Reply #7 on: December 08, 2014, 09:29:16 pm »
He also injected it into my elitef4menu. Who ever has that addon check the elitef4menu/lua/autorun/server/elite_crash.lua and you could potentially find it in there. Working fine now THANKS!
