Author Topic: Setting Engine Cvars?  (Read 6833 times)
Offline PAL-18
« on: October 31, 2014, 01:24:20 pm »
I have a bunch of engine cvars im trying to set to custom valid values (sk_barnacle_health, etc.) and i'm unable to get them to set.  In server.cfg it isin't applying and they even fail when added to init.lua in the gamemode.
I've tried the following code:
RunConsoleCommand("sk_barnacle_health", "1000")
Any idea how i can get it to apply?
« Last Edit: October 31, 2014, 04:05:20 pm by PAL-18 »
Offline Avoid
Re: Setting Engine Cvars?
« Reply #1 on: November 01, 2014, 05:12:52 am »
Hello there,
have you actually created the convars using CreateConVar?
You can also define convars in your gamemode.txt:
"settings"
"name" "sk_maxfrags"
"text" "Max Frags"
"help" "The maxiumum number of frags before a map change"
"type" "Numeric"
"default" "20"
2
"name" "sk_grenades"
"text" "Allow Grenades"
"help" "If enabled ) then grenades are enabled"
"type" "CheckBox"
"default" "1"
Avoid
Offline PAL-18
« Reply #2 on: November 01, 2014, 03:04:52 pm »
They aren't custom cvars though.  They're cvars common to the SRCDS engine (they work in Gmod too).
I just tried that and it didnt work either.
« Last Edit: November 01, 2014, 03:11:36 pm by PAL-18 »
Offline Avoid
« Reply #3 on: November 01, 2014, 05:38:30 pm »
Ah, I see.
Sorry I didn't know such a convar existed! :')
Use a timer when setting the convar in the Initialize hook and it worked fine on my end:
timer.Simple(0.1, function()
RunConsoleCommand("sk_barnacle_health", "500")
end)
Offline PAL-18
« Reply #4 on: November 02, 2014, 12:53:49 am »
Do you have the full code you used to get it to work?  I tried adding that timer to several places and i couldnt get it working.
Offline Avoid
« Reply #5 on: November 02, 2014, 02:59:07 am »
As I've written in my post earlier, simply put this into your Initialize hook.
You can either overwrite the hook or simply add to it. :)
Offline PAL-18
« Reply #6 on: November 04, 2014, 02:58:56 am »
Oh.
I didn't notice; but i did add it to my GM:Initialize hook.  It didn't work.
Here's part of what it looks like:
function GM:Initialize()
   MsgN("Trouble In Terrorist Town gamemode initializing...")
   ShowVersion()
   -- Force friendly fire to be enabled. If it is off, we do not get lag compensation.
   RunConsoleCommand("mp_friendlyfire", "1")
   -- NPC Cvars
RunConsoleCommand("sk_antlionguard_health", "300")
RunConsoleCommand("sk_antlionguard_dmg_charge", "7")
RunConsoleCommand("sk_antlionguard_dmg_shove", "2")
RunConsoleCommand("sk_antlion_health", "150")
RunConsoleCommand("sk_antlion_jump_damage", "5")
RunConsoleCommand("sk_antlion_swipe_damage", "1")
end)
« Last Edit: November 04, 2014, 03:00:34 am by PAL-18 »
Offline PAL-18
« Reply #7 on: November 09, 2014, 02:28:55 pm »
Sooo ... any idea why it doesnt work?
Offline Zmaster
« Reply #8 on: November 09, 2014, 02:32:51 pm »
Does it give an error?
Offline PAL-18
« Reply #9 on: November 10, 2014, 03:27:26 am »
Nope, no errors.  It just doesn't seem to accept the cvar.
Oddly if i do the cvar through rcon remotely or ulx rcon it runs fine.
Offline PAL-18
« Reply #10 on: November 10, 2014, 09:36:02 pm »
I managed to get it working myself by moving the timer from GM:Initialize function to BeginRound function.
Thanks for all the help :D
