Author Topic: HUD Code Makes Me Crash  (Read 5308 times)
Offline Zmaster
« on: November 09, 2014, 11:37:22 am »
I wanted to start working with HUDs yesterday, so I found a video on YouTube for it and then fixed the code he showed (His code was outdated and produced errors)
After making it work with GM13, I realized whenever I was on my server running the code for a few minutes, I would crash out of GMod with no errors or anything
I get no errors on the code and my game shows no errors when I crash
My GMod will just suddenly close
I'm sure this code is making me crash, because when I moved it to another folder where the code wouldn't run, I stopped crashing
  1. //include( "shared.lua" )
  2.
  3. hook.Add( "HUDShouldDraw", "hidethehud", function( name )
  4.         if (name == "CHudHealth" or name == "CHudBattery" or name == "CHudAmmo") then return false end end )
  5.
  6. function PaintZeeHud()
  7.         local ply = LocalPlayer()
  8.         local HP = ply:Health()
  9.         local ARM = ply:Armor()
  10.         local NewScrH = (ScrH() - 50 )
  11.
  12.         draw.RoundedBox( 10, 10, NewScrH - 30, 75, 75, Color( 87, 81, 81, 255 ) )
  13.         surface.CreateFont( "ZeeFont", {
  14.         font = "ScoreboardText",
  15.         size = 40,
  16.         weight = 255,
  17.         antialias = false,
  18.         underline = false,
  19.         italic = false,
  20.         })
  21.         surface.SetTextColor( 0, 0, 255, 255 )
  22.         if (ply:Health() == 100) then
  23.                 surface.SetTextPos( 20, NewScrH - 14)
  24.         elseif (ply:Health() == 0) then
  25.                 surface.SetTextPos( 39, NewScrH - 14 )
  26.         else
  27.                 surface.SetTextPos( 30, NewScrH - 14 )
  28.         end
  29.         surface.SetFont( "ZeeFont" )
  30.         surface.DrawText( HP )
  31. end
  32. hook.Add( "HUDPaint", "PaintZeeHUDHook", PaintZeeHud )
Does anyone know what I did wrong?
Line 1 is commented out because I didn't create a shared.lua file yet
Offline Dog
Re: HUD Code Makes Me Crash
« Reply #1 on: November 11, 2014, 07:49:08 pm »
I didn't know if that was a default font or not so I went with Arial. The HUD worked for me after I changed the function name and removed a hook:
  2.
  5.
  6. function GM:HUDPaint()
  11.
  14.         font = "Arial",
  15.         size = 40,
  16.         weight = 255,
  19.         italic = false,
  20.         })
  26.         else
  28.         end
  31. end
Offline Zmaster
« Reply #2 on: November 12, 2014, 07:50:17 pm »
Getting this error on that code
Why would GM: not be recognized?
« Reply #3 on: November 12, 2014, 08:23:31 pm »
Ouch Zmaster, learn to copy/paste text from console :P
I've little to no experience with gamemode, but probably cause GM has to be registered in some way.
Had some oddity like that with a script many years ago.
Had to go from GM to "gamemode" or something like that.
GAMEMODE perhaps.
SOrry, don't fully remember.
Offline Zmaster
« Reply #4 on: November 13, 2014, 12:33:21 pm »
Okay...
Changed GM to GAMEMODE and no longer got an error
However, after a minute or two of severe lag on my computer (was getting this lag before I came here for help), GMod will crash.
Again, no errors
I just start lagging a ton, then my game closes and the lag stops
I've tried reinstalling my game and removing unnecessary addons and even verified my game cache, but the problem is still occuring
« Reply #5 on: November 13, 2014, 04:16:54 pm »
Did you try "Dog's" code, not using a custom font?
If not, try that.
If that works, investigate to see if a font can/should be created outside of HUDPaint, then used within it.
I would imagine creating a font every frame draw, even the same one, might not be the proper way to do it.
(Again, I'm inexperienced here...I've never worked with GUI in Gmod)
Offline Dog
« Reply #6 on: November 13, 2014, 07:41:10 pm »
Okay, so a non-laggy code I have got:
  1. include( "shared.lua" )
  2.
  5.
  6. surface.CreateFont( "ZeeFont", {
  7.         font = "Arial",
  8.         size = 40,
  9.         weight = 255,
  10.         antialias = false,
  11.         underline = false,
  12.         italic = false,
  13.         })
  14.
  15. function GAMEMODE:HUDPaint()
  16.         local ply = LocalPlayer()
  17.         local HP = ply:Health()
  18.         local ARM = ply:Armor()
  19.         local NewScrH = (ScrH() - 50 )
  20.
  21.         draw.RoundedBox( 10, 10, NewScrH - 30, 75, 75, Color( 87, 81, 81, 255 ) )
  22.         surface.SetTextColor( 0, 0, 255, 255 )
  23.         if (ply:Health() == 100) then
  24.                 surface.SetTextPos( 20, NewScrH - 14)
  25.         elseif (ply:Health() == 0) then
  26.                 surface.SetTextPos( 39, NewScrH - 14 )
  27.         else
  28.                 surface.SetTextPos( 30, NewScrH - 14 )
  29.         end
  30.         surface.SetFont( "ZeeFont" )
  31.         surface.DrawText( HP )
  32. end
  33.
To import a font you can just make a simple addon(that's how I did it) and then it'll download to the client.
  1. if SERVER then
  2.         resource.AddSingleFile("resource/fonts/<font file name here>.ttf")
  3. end
« Last Edit: November 13, 2014, 07:47:39 pm by Dog »
« Reply #7 on: November 13, 2014, 07:56:26 pm »
So it does seem like creating a font every frame is what is causing the issue.
My educated guessing sometimes works. :)
Offline Zmaster
« Reply #8 on: November 14, 2014, 05:47:59 am »
haha
I didn't even think about that, but now that you mention it, it would make sense to make the font outside of the GAMEMODE:HudPaint
Thanks for the help, JamminR and Dog
