Author Topic: Sourceban Small integration error  (Read 6414 times)
Offline Schiaffino
« on: November 28, 2014, 07:02:15 pm »
Hello guys, well i've seen all the threadas about sourceban here and none of them solve my issue so im wondering if someone can help me to figure this out ?
function ulx.sban( calling_ply, target_ply, minutes, reason )
if target_ply:IsBot() then
ULib.tsayError( calling_ply, "Cannot ban a bot", true )
return
SBAN.Player_Ban( target_ply, minutes*60, reason, calling_ply:SteamID() )
local time = "for #i minute(s)"
if minutes == 0 then time = "permanently" end
local str = "#A banned #T " .. time
if reason and reason ~= "" then str = str .. " (#s)" end
ULib.queueFunctionCall( ULib.addBan, target_ply, minutes, reason, name, calling_ply )
ulx.fancyLogAdmin( calling_ply, str, target_ply, minutes ~= 0 and minutes or reason, reason )
local sban = ulx.command( CATEGORY_NAME, "ulx sban", ulx.sban, "!sban" )
sban:addParam{ type=ULib.cmds.PlayerArg }
sban:addParam{ type=ULib.cmds.NumArg, hint="minutes, 0 for perma", ULib.cmds.optional, ULib.cmds.allowTimeString, min=0 }
sban:addParam{ type=ULib.cmds.StringArg, hint="reason", ULib.cmds.optional, ULib.cmds.takeRestOfLine, completes=ulx.common_kick_reasons }
sban:defaultAccess( ULib.ACCESS_ADMIN )
sban:help( "Bans target." )
This code works 95% the only issue is that when you ban the user instead of giving the user name gives this
And this small error at the console huh
Sorry for bothering you about this guys but nay help,
Really thanks !
Offline Schiaffino
Re: Sourceban Small integration error
« Reply #1 on: November 28, 2014, 07:24:04 pm »
After moving the function:
return
To this position, it works but at sourceban's says "E" ( expired ) inmediately and still the same console error ID error....
Offline Neku
« Reply #2 on: November 28, 2014, 10:44:45 pm »
Offline Schiaffino
« Reply #3 on: November 28, 2014, 11:34:52 pm »
The problem is that i'm using the latest revision from the github, downloaded today huh :/
Offline Avoid
« Reply #4 on: November 29, 2014, 05:40:58 am »
Hello there, try this:
                return
        if calling_ply:IsValid() then
                SBAN.Player_Ban( target_ply, minutes*60, reason, "STEAM_ID_SERVER")
For sourcebans: Try banning longer than a minute and see if the ban expires immediately.
EDIT:
Also in your queued function call, try using the targeted player SteamID instead of the target player. See addBan
Avoid
« Last Edit: November 29, 2014, 05:46:32 am by Avoid »
Offline Schiaffino
« Reply #5 on: November 29, 2014, 11:27:22 am »
Thanks Avoid! did it to implement it to the xgui menu and it works without the ID error now.
The only issue im having is that at SB website its showing "Expire" Inmediately :/ i'll make a few attempts
« Last Edit: November 29, 2014, 04:29:05 pm by Schiaffino »
Offline Schiaffino
« Reply #6 on: November 29, 2014, 11:54:20 am »
EDIT: Works perfect no ID error but when i set less than 5 hours for some reason it says "E
Really thanks for the quick reply !
« Last Edit: November 29, 2014, 04:05:52 pm by Schiaffino »
Offline Avoid
« Reply #7 on: November 30, 2014, 03:32:10 am »
Hello there,
this is indeed a weird error, make sure you actually use the correct timezone in sourcebans and have a look through your code to see if the time is inserted correctly into the database.
Avoid
