Return command not working.
Topic: Return command not working. (Read 4619 times)
preben1
December 08, 2014, 10:01:18 am »
All the other commands works, but the return command does not work for some reason.
Thanks.
Megiddo
Ulysses Team Member
Project Lead
Re: Return command not working.
December 08, 2014, 06:06:01 pm »
Do you get any errors in console?
Caustic Soda-Senpai
Sr. Member
<Insert something clever here>
Reply #2 on:
December 11, 2014, 10:27:00 am »
are you trying to use the return command BEFORE using a teleport command?
preben1
Reply #3 on:
December 11, 2014, 05:58:19 pm »
No i am not, and also there is no errors with ulx in console.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #4 on:
December 11, 2014, 08:51:31 pm »
Um... unlikely.
Unless another addon is overwriting return, and, if there is truly no error, I'm guessing that's what your issue is, there will be an error.
Check server console. Check game console.
If no error, it's another addon conflict.
preben1
Reply #5 on:
December 27, 2014, 02:29:33 am »
I still haven't found out what's causing the problems, i even redownloaded it.
preben1
Reply #6 on:
January 01, 2015, 06:38:23 am »
I'm still looking for some help regarding this issue, i have re-installed ulx.
Caustic Soda-Senpai
Sr. Member
Reply #7 on:
January 01, 2015, 07:36:18 am »
Easiest Solution:
1) Remove all addons except ULX.
2) Enter the server and try the return command
3) If it works, you have a conflicting addon and can continue through the steps. If it doesn't, then skip to Step 8.
4) Add one addon into your server and perform a full Server Restart.
5) Go into your server and try the return command.
6) Repeat steps 4 & 5 until it stops working.
7) Find the addon you just added and tell us what it is.
8 ) You done pooched.
