Author Topic: Recycling Parts of users.txt  (Read 5154 times)
Offline Bryantdl7
« on: December 18, 2014, 02:54:55 pm »
My users.txt is massive as I use apromote to add people to custom ranks. I was wondering if there is a way to easily delete all users from rank eg. vault-guardian without using notepad++ and deleting one at a time for the next 30 years.
Re: Recycling Parts of users.txt
« Reply #1 on: December 18, 2014, 04:15:36 pm »
Wouldn't XGUI allow removing users from groups be quicker?
Though it might still have to be done one at a time, would be easier to 'select group' 'select player' 'click remove button' than it would be to manually edit text.
I know of no ULX command to remove mass at once (and, with good reason!)
Offline xXthatNAVYguyXx
« Reply #2 on: December 18, 2014, 10:27:42 pm »
If you wanted to remove all users from a single rank, you could just delete the rank through the in-game GUI. Make sure you make a rank just like it and make that rank have all the same features. Then once you delete the original, replace it with the "copy" so you still have the rank. :)
Offline Bryantdl7
« Reply #3 on: December 20, 2014, 03:43:58 pm »
I have approx. 3,000 in some ranks. That would be impossible lol
Offline Bryantdl7
« Reply #4 on: December 20, 2014, 03:45:01 pm »
I don't want to delete the people in the rank. I just want less then a million people in my users.txt. I doubt deleting the rank would affect the file at all
« Reply #5 on: December 21, 2014, 06:36:11 pm »
Compression is the obvious answer to this question, but unfortunately that's not a supported solution by Garry. :P
The development team has been working on a SQLite version of the user database, but there's no ETA on this.
