How to I block the drive tool in gmod
Topic: How to I block the drive tool in gmod (Read 7685 times)
Phillip Latchford
December 19, 2014, 07:54:40 am »
How to I block the drive tool in Garry's mod and can I use ulx to do that
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Re: How to I block the drive tool in gmod
December 19, 2014, 10:24:57 am »
ULX by itself doesn't block tools.
See the releases section of our forum. Several releases there might assist in blocking tools.
If that doesn't work, try asking for code addition/assistance in Developers corner.
Caustic Soda-Senpai
Sr. Member
<Insert something clever here>
Reply #2 on:
December 19, 2014, 10:41:02 am »
Got this from this source:
http://forum.darkrp.com/threads/disabling-certain-tool-guns.752/
REQUIRES:
Falco's Prop Protection
1. Hit Q menus
2. On the right hand side at the top, click the "Utilities" tab
3. Look for menu "Falco's Prop Protection"
4. Expand out "Tool Restrictions"
5. Under "Construction" folder select "[drive]"
6. You will notice the word "[drive]" is now under "Tool Names" (don't click it or anything)
7. Click "Edit/view selected tool restrictions"
8. Tick the "Admin" box if you want just admins to use it, or "Superadmin" for just super admins.
Last Edit: December 19, 2014, 10:53:38 am by syst3M4TiK
Caustic Soda-Senpai
Sr. Member
Reply #3 on:
December 19, 2014, 01:14:40 pm »
After checking myself, make sure the category you expand in Step 5 is the category with "drive" in it.
