Author Topic: Is it possible to disable pvp on a certain part of the map with lua?  (Read 4374 times)
Offline Jaden Zepeda
For instance the platform in the middle of flatgrass, disable pvp on the platform but make the ground around it pvp?
Offline Avoid
Re: Is it possible to disable pvp on a certain part of the map with lua?
« Reply #1 on: December 20, 2014, 11:37:51 am »
Hello there,
you could create a SENT, check if there are players "Touching" it and adjust the GM:EntityTakeDamage hook accordingly.
If you do not want to use a SENT, you could do that directly within the EntityTakeDamage hook by using FindInBox.
Thats at least two methods I can currently think of.
Avoid
« Reply #2 on: December 29, 2014, 12:07:13 pm »
Hmmm, how would I do this? Im sorry, I am still pretty new to lua coding.
My server has a rule against killing on the platform in the middle of flatgrass and Im trying to figure out how I can disable platform killing so its no longer an issue, someone told me about using spheres or something like that.
Offline BobTheDuck69
« Reply #3 on: March 12, 2015, 11:52:06 am »
There is a simple safezone addon in workshop somewhere. if its a sandbox server theres also buildmode.
~The friendly neighborhood duckie~
