Author Topic: 2 Command Scripts interfering...  (Read 5406 times)
Offline Jaden Zepeda
« on: December 20, 2014, 02:55:48 pm »
I have 2 lua files, group.lua and donate.lua, both in my autorun server. Lets say I lua_openscript group.lua and lua_openscript donate.lua right after, only !donate works because it was the last one I ran, is there a way to make it so both of them work at the same time?
Donate.lua
function donateCommand( pl, text, teamonly )
    if (text == "!donate") then
    pl:SendLua([[gui.OpenURL("http://sites.google.com/site/bigmacssw/donate")]]) -- Change ADDRESS to your chosen page.
hook.Add( "PlayerSay", "Chat", donateCommand )
Group.lua
function groupCommand( pl, text, teamonly )
    if (text == "!group") then
    pl:SendLua([[gui.OpenURL("http://steamcommunity.com/groups/sandboxwars")]]) -- Change ADDRESS to your chosen page.
hook.Add( "PlayerSay", "Chat", groupCommand )
Re: 2 Command Scripts interfering...
« Reply #1 on: December 20, 2014, 03:14:41 pm »
Your hook add command uses the same "identifier" for both commands. "Chat"
That middle term has to be unique, or it overwrites previous.
From hook.Add
hook.Add( string eventName, any identifier, function func )
any identifier
The unique identifier, usually a string. This can be used to replace or remove existing hooks. If the identifier is not a string and IsValid(identifier) returns false on the hook's call, the hook will be removed.
« Reply #2 on: December 20, 2014, 03:24:13 pm »
From hook.Add
Wow, Im so stupid I can't believe I missed that! Thanks alot!
« Reply #3 on: December 20, 2014, 09:07:42 pm »
It's the small details that will get you everytime.
You're welcome.
