Author Topic: JailPOS Broken  (Read 6000 times)
Offline m0neyman99
JailPOS Broken
« on: December 22, 2014, 05:28:41 am »
I don't understand whats going on, we are creating a new dedicated darkrp server.
Im the second developer to work on the files, so honestly I don't know if core files were messed with.
Everytime we go to set /jailpos tho, a little bubble pops up saying "Admin only"
Now im developer so my admin abilities are set to max, i set my FAdmin access to superadmin as well.
Idk if this is a problem with ulx or what the deal is. I've done everything i can think of!!! Please any help is appreciated! We are struggling so hard!
Re: JailPOS Broken
« Reply #1 on: December 22, 2014, 07:23:31 am »
You'd really need to ask who ever created the "JailPOS" command what it's checking for.
If you have ULX superadmin, which inherits admin, but Fadmin does it's own thing (we often recommend disable of Fadmin due to access conflicts), it's extremely difficult to sort out.
"ulx who" from your game console will tell you at least what group ULX sees you as.
Offline Caustic Soda-Senpai
    • Steam Page
Re: JailPOS Broken
« Reply #2 on: December 22, 2014, 03:35:17 pm »
Make sure you are INHERITING from an Admin Rank. I had this issue once before
Offline m0neyman99
Re: JailPOS Broken
« Reply #3 on: December 22, 2014, 06:58:45 pm »
Super admin inherits from admin. Idk who the created jailpos command but I have been assuming it's an FAdmin problem. How do I go about disabling FAdmin? We shall see if that fixes the problem. Thanks for all the help guys!
    • Steam Page
Re: JailPOS Broken
« Reply #4 on: December 22, 2014, 08:43:19 pm »
Assuming you have the modification folder in your addons for DarkRP, to disable FAdmin, go to
darkrpmodification/lua/darkrp_config/disabled_defaults.lua
and change Line 35 to true
This is a blank darkrp changed to your requirement:
  1. DarkRP.disabledDefaults["modules"] = {
  2.         ["afk"]              = false,
  3.         ["chatsounds"]       = false,
  4.         ["events"]           = false,
  5.         ["fpp"]              = false,
  6.         ["f1menu"]           = false,
  7.         ["f4menu"]           = false,
  8.         ["hitmenu"]          = false,
  9.         ["hud"]              = false,
  10.         ["hungermod"]        = true,
  11.         ["playerscale"]      = false,
  12.         ["sleep"]            = false,
  13.         ["fadmin"]           = true, -- Line 35
  14. }
Re: JailPOS Broken
« Reply #5 on: December 23, 2014, 03:28:33 pm »
As covered in the DarkRP Wiki link from our FAQ "How do I remove Fadmin from DarkRP"
