Author Topic: The lua box.  (Read 9613 times)
Offline DannyMartinez
The lua box.
« on: April 04, 2007, 07:44:43 pm »
I dont get. so i add thise _ = nil -- Make sure we're starting out right.
local old__newindex = _G.__newindex
setmetatable( _G, _G )
function _G.__newindex( t, k, v )
if k == "_" then
-- If you care enough to fix bad scripts uncomment this following line.
-- error( "attempt to modify global variable '_'", 2 )
return
if old__newindex then
old__newindex( t, k, v )
rawset( t, k, v )
end to the addons folder?But i dont get it.Do i name the folder the thing?Or do i put it in a text document?
Re: The lua box.
« Reply #1 on: April 04, 2007, 07:47:53 pm »
Wait o i add a .lua at the end of the folder or do i add .lua at the end of the thing  like thise t_ = nil -- Make sure we're starting out right.
if k == "_" then
return
rawset( t, k, v )
end.lua
Re: The lua box.
« Reply #2 on: April 04, 2007, 08:16:09 pm »
You put it in a file in autorun, just make sure it has .lua as the extension.
Re: The lua box.
« Reply #3 on: April 04, 2007, 08:53:46 pm »
As a text doucement?
Offline spbogie
Re: The lua box.
« Reply #4 on: April 04, 2007, 09:02:38 pm »
1) Open Notepad
2) Copy the text below
if k == "_" then
return
rawset( t, k, v )
3) Paste it into notepad
4) File -> Save As
5) Save to /garrysmod/lua/autorun/ as "underscorefix.lua" (With the quotes)
Re: The lua box.
« Reply #5 on: April 05, 2007, 07:09:26 am »
But how do I turn the box into a code?
Re: The lua box.
« Reply #6 on: April 05, 2007, 07:33:43 am »
And how do i put quotes? like with 2 of ' that?
Re: The lua box.
« Reply #7 on: April 05, 2007, 07:43:53 am »
The code like thise?
if k == "_" then
return
rawset( t, k, v )
Offline spbogie
Re: The lua box.
« Reply #8 on: April 05, 2007, 12:14:40 pm »
Ok, I don't know how much easier I can make it.
1) Go to http://www.ulyssesmod.net and copy the code.
2) Open up notepad.
3) Paste the code you just coppied into notepad.
4) Save As...
5) Navigate to "<Steam directory>/SteamApps/<account name>/garrysmod/garrysmod/lua/autorun" for listen server, or "<SRCDS dir>/garrysmod/lua/autorun" for dedicated server"
6) Save the file as "underscorefix.lua" (With the qotes) ( " is < Shift + ' > )
If you can't get it from that then I'm sorry but I can't make it any easier.
Re: The lua box.
« Reply #9 on: April 05, 2007, 04:31:44 pm »
Thank you!
Re: The lua box.
« Reply #10 on: April 05, 2007, 04:36:08 pm »
Posted on front page. Thanks spbogie!
Re: The lua box.
« Reply #11 on: April 05, 2007, 04:45:02 pm »
IT WORKS :D TYTYYTYTYYT spbogie!
Re: The lua box.
« Reply #12 on: April 05, 2007, 06:36:21 pm »
SpBogie, hats off to you.
You have more patience than I've had in a while.
A long while.
