Author Topic: RDM Manager Report Perms  (Read 4271 times)
Offline MaxKittens
« on: December 28, 2014, 02:05:45 pm »
Hello, so I am making a ttt server and I want to have everyone above trial mod able to have reports submitted to them when they are on. I am Owner and even I don't get the perms for someone to submit a report to me! I am currently testing but will have my server up very soon. I need to fix this problem because I want to test trial-mods how they deal with reports and if they're worthy.
Thanks
                    -MaxKittyGuy
Offline Dharmvir Sidhu
    • OMENS Gaming
Re: RDM Manager Report Perms
« Reply #1 on: December 28, 2014, 03:52:52 pm »
go into TTTDamagelogs-master (or whatever you called the folder) > lua > damagelogs > config > config.lua
in there, change your code.
for example, mine is
  1. Damagelog:AddUser("owner", 4, true)
  2. Damagelog:AddUser("co-owner", 4, true)
  3. Damagelog:AddUser("superadmin", 4, true)
  4. Damagelog:AddUser("admin", 4, true)
  5. Damagelog:AddUser("operator", 1, true)
  6. Damagelog:AddUser("mlgpro", 1, true)
  7. Damagelog:AddUser("master chief", 1, true)
  8. Damagelog:AddUser("donor mod", 1, true)
  9. Damagelog:AddUser("trial mod", 1, true)
  10. Damagelog:AddUser("user", 1, false)
  11. Damagelog:AddUser("guest", 1, false)
whenever you need to add another rank to be able to view the logs, just copy a line, paste it, edit the name in the quotes, (1 if you want them to only be able to view the previous rounds damagelods, 4 if also current rounds damagelogs which isnt a good idea for everyone) then true if you want them to be able to see the rdm manager
