Author Topic: Help again with RunConsoleCommand  (Read 10187 times)
Offline [TBR] Lt Usher
    • http://www.itwasntme.co.uk
« on: December 29, 2014, 06:52:21 am »
Ok, I'm stuck its struggling to identify the variables i.e. "v" as the target player and "credits" as the value. Please help!
local CATEGORY_NAME  = "Day-Z Admin"
local gamemode_error = "The current gamemode is not Gmod Day-Z"
------------------------------ Give Credits ------------------------------
function ulx.givecredits( calling_ply, target_plys, credits )
if not GetConVarString("gamemode") == "dayz" then ULib.tsayError( calling_ply, gamemode_error, true ) else
local affected_plys = {}
for i=1, #target_plys do
local v = target_plys[ i ]
RunConsoleCommand("dz_giveitem", "item_credits", v, credits )
table.insert( affected_plys, v )
ulx.fancyLogAdmin( calling_ply, "#A gave #T credit to #i.", affected_plys, credits )
local givecredit = ulx.command( CATEGORY_NAME, "ulx givecredits", ulx.givecredits, "!givecredits" )
givecredit:addParam{ type=ULib.cmds.PlayersArg }
givecredit:addParam{ type=ULib.cmds.NumArg, hint="The credit the player should get.", min=1, default=1 }
givecredit:defaultAccess( ULib.ACCESS_ADMIN )
givecredit:help( "Gives credit to a player." )
------------------------------ Give Money ------------------------------
function ulx.givemoney( calling_ply, target_plys, money )
RunConsoleCommand("dz_giveitem", "item_money", v, money )
ulx.fancyLogAdmin( calling_ply, "#A gave #T money to #i.", affected_plys, money )
local givemoney = ulx.command( CATEGORY_NAME, "ulx givemoney", ulx.givemoney, "!givemoney" )
givemoney:addParam{ type=ULib.cmds.PlayersArg }
givemoney:addParam{ type=ULib.cmds.NumArg, hint="The money the player should get.", min=1, default=1 }
givemoney:defaultAccess( ULib.ACCESS_ADMIN )
givemoney:help( "Gives money to a player." )
Re: Help again with RunConsoleCommand
« Reply #1 on: December 29, 2014, 09:47:17 am »
For one, the target_plys table stores Player objects. You would want to use target_plys:Nick() for the player's name.
Second off, you'd probably want to run RunConsoleCommand server-side, probably with net messages. As it stands now, you're running it on the client and server.
« Last Edit: December 29, 2014, 11:26:41 am by Bytewave »
« Reply #2 on: December 29, 2014, 11:57:05 am »
Can I be so bold as to ask you to alter as I'm not 100% sure?
« Reply #3 on: December 29, 2014, 01:05:31 pm »
I suppose, one moment. I'll edit back when I'm done.
EDIT: Untested, but here 'ya go.
  1. if SERVER then
  2.         util.AddNetworkString( "ulx_dayz_admin" )
  3.
  4.         net.Receive( "ulx_dayz_admin",
  5.                 function()
  6.                         game.ConsoleCommand( net.ReadString() )
  7.                 end
  8.         )
  9. end
  10.
  11. local CATEGORY_NAME  = "Day-Z Admin"
  12. local gamemode_error = "The current gamemode is not Gmod Day-Z!"
  13.
  14. ------------------------------ Give Credits ------------------------------
  15. function ulx.givecredits( calling_ply, target_plys, credits )
  16.         if not GetConVarString("gamemode") == "dayz" then
  17.                 ULib.tsayError( calling_ply, gamemode_error, true )
  18.         else
  19.                 local affected_plys = {}
  20.
  21.                 for i=1, #target_plys do
  22.                         local v    = target_plys[ i ]
  23.                         local name = v:Nick()
  24.
  25.                         local ccstring =        "dz_giveitem item_credits" .. name .. credits .. "\n"
  26.
  27.                         net.Start( "ulx_dayz_admin" )
  28.                                 net.WriteString( ccstring )
  29.                         net.SendToServer()
  30.
  31.                         table.insert( affected_plys, v )
  32.                 end
  33.
  34.                 ulx.fancyLogAdmin( calling_ply, "#A gave #i credit(s) to #T.", affected_plys, credits )
  35.         end
  36.
  37. end
  38.
  39. local givecredit = ulx.command( CATEGORY_NAME, "ulx givecredits", ulx.givecredits, "!givecredits" )
  40. givecredit:addParam{ type=ULib.cmds.PlayersArg }
  41. givecredit:addParam{ type=ULib.cmds.NumArg, hint = "credits", min = 1, default = 1 }
  42. givecredit:defaultAccess( ULib.ACCESS_ADMIN )
  43. givecredit:help( "Gives credits to players." )
  44.
  45. ------------------------------ Give Money ------------------------------
  46. function ulx.givemoney( calling_ply, target_plys, money )
  47.         if not GetConVarString("gamemode") == "dayz" then
  48.                 ULib.tsayError( calling_ply, gamemode_error, true )
  49.         else
  50.                 local affected_plys = {}
  51.
  52.                 for i=1, #target_plys do
  53.                         local v    = target_plys[ i ]
  54.                         local name = v:Nick()
  55.
  56.                         local ccstring =        "dz_giveitem item_money" .. name .. credits .. "\n"
  57.
  58.                         net.Start( "ulx_dayz_admin" )
  59.                                 net.WriteString( ccstring )
  60.                         net.SendToServer()
  61.
  62.                         table.insert( affected_plys, v )
  63.                 end
  64.
  65.                 ulx.fancyLogAdmin( calling_ply, "#A gave #i money to #T.", affected_plys, money )
  66.         end
  67.
  68. end
  69.
  70. local givemoney = ulx.command( CATEGORY_NAME, "ulx givemoney", ulx.givemoney, "!givemoney" )
  71. givemoney:addParam{ type = ULib.cmds.PlayersArg }
  72. givemoney:addParam{ type = ULib.cmds.NumArg, hint = "money", min = 1, default = 1 }
  73. givemoney:defaultAccess( ULib.ACCESS_ADMIN )
  74. givemoney:help( "Gives money to players." )
« Last Edit: December 29, 2014, 01:14:43 pm by Bytewave »
« Reply #4 on: December 29, 2014, 01:54:37 pm »
Thank you I'll test it and send back update. Thanks again
« Reply #5 on: December 30, 2014, 04:55:32 am »
it's kicking an error
[ERROR] addons/ulx/lua/ulx/modules/sh/dayzbank.lua:42: attempt to call field 'SendToServer' (a nil value)
[ERROR] addons/ulx/lua/ulx/modules/sh/dayzbank.lua:73: attempt to call field 'SendToServer' (a nil value)
« Last Edit: December 30, 2014, 04:58:44 am by [TBR] Lt Usher »
Offline bender180
    • Benders Villa
« Reply #6 on: December 30, 2014, 01:39:29 pm »
The issue here is that you haven't defined SendToServer as anything its a nil value it does nothing and it always will do nothing until you define it to do something.
« Reply #7 on: December 30, 2014, 02:51:05 pm »
http://wiki.garrysmod.com/page/net/SendToServer
Is that even the addon code I sent? 'Cause that code calls SendToServer on 29 and 60.
« Reply #8 on: December 30, 2014, 03:11:01 pm »
Yep it's deffinatly the same code and I'm not sure why it's pulling a nill value
« Reply #9 on: December 31, 2014, 04:33:37 am »
nope the new code doesn't work either
local CATEGORY_NAME  = "Day-Z Bank Admin"
local steamid = v:SteamID()
local ccstring = ("dz_giveitemid ".. steamid .." item_credits ".. credits .."\n")
if SERVER then
game.ConsoleCommand( ccstring )
ulx.fancyLogAdmin( calling_ply, "#A gave #T #i credit(s)", affected_plys, credits )
local ccstring = "dz_giveitemid ".. steamid .." item_money ".. money .."\n"
if SERVER then
ulx.fancyLogAdmin( calling_ply, "#A gave #T #i money", affected_plys, money )
Error:
Bad SetLocalOrigin(13963.000000,19502.000000,34.000000) on gmod_hands (602)
[TBR] Lt Usher gave Themself 1 credit(s)
ServerLog: [ULX] [TBR] Lt Usher gave Themself 1 credit(s)
Player STEAM_0 doesn't exist in the database! They've never joined the server!
From what I can make of it is the steam id is not infilling in full please help!
« Last Edit: December 31, 2014, 07:18:45 am by [TBR] Lt Usher »
Offline Buzzkill
    • The Hundred Acre Bloodbath
« Reply #10 on: December 31, 2014, 10:30:08 am »
Silly question, but are you testing in single player?
« Reply #11 on: December 31, 2014, 04:02:42 pm »
No, it's hosted on a test bed server
« Reply #12 on: December 31, 2014, 04:20:57 pm »
GameConsole command is likely choking on the colon ":" in the steamid.
Partial reason IMO that Gmod went to using player ids.
There are ways around it, I don't remember off top of my head.
Might try escaping out some quotes so it tries to wrap the colon in quotes?
local ccstring = ("dz_giveitemid \"".. steamid .."\" item_credits ".. credits .."\n")
Does dz_giveitemid have to be passed a steam ID?
Can't it handle a name or player object? (if it's only steamid, bad design imo)
« Reply #13 on: December 31, 2014, 10:38:21 pm »
Unfortunately it will only take a steamid as it enters Into a MySQL database, dz_giveitem works with players name but didn't have much luck there either for some reason?
