Author Topic: Ranks missing  (Read 4404 times)
Offline Brandon Curtis
Ranks missing
« on: December 29, 2014, 06:17:40 pm »
When I installed ulx superadmin wasnt a rank so I created it but is this normal and how do I add permissions to my group?
Re: Ranks missing
« Reply #1 on: December 29, 2014, 07:29:51 pm »
No, it's not normal.
"superadmin" is a default rank in Gmod, and ULX adds permissions to it on it's own, along with admin, that superadmin inherits, then operator, that both inherit.
Operator doesn't have much, it's more like a "example" custom group for ULX.
From server console, use "ulx resettodefaults", and then make sure you have latest ULib and ULX from https://github.com/Nayruden/Ulysses and then make sure you follow instructions for adding self as superadmin (if using non-listen server).
Remember, case sensitive. superadmin not Superadmin.
Re: Ranks missing
« Reply #2 on: December 30, 2014, 04:52:00 am »
Ok I did that command but there is like no permissions for me to make groups/edit groups.
Offline Caustic Soda-Senpai
    • Steam Page
Re: Ranks missing
« Reply #3 on: December 30, 2014, 05:52:30 am »
Delete your ULX in addons then
If it persists, then delete the ulx & ulib in the data folders as well then reinstall.
Re: Ranks missing
« Reply #4 on: December 30, 2014, 04:13:21 pm »
Sounds like you have some conflicting addon or gamemode (or, your not actually checking every step like mentioned).
DarkRP? Disable Fadmin and try again.
See also FAQ "Having trouble with access?"
We'll know your not performing all steps in that FAQ if you don't give certain info for us to try to help you.
