General
Off-Topic
Map config files?
Topic: Map config files? (Read 5342 times)
Sgt.Blue
Map config files?
January 03, 2015, 02:05:18 pm »
I have noticed that when starting a multi-slot listen the console prints a message that reads; '(map name).cfg not present, not executing.'
If such a file were present, where would it be and what would it do?
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Re: Map config files?
January 03, 2015, 07:44:53 pm »
/cfg/ I would guess, where all the other server and autoexec cfg files go.
Neku
Reply #2 on:
January 03, 2015, 11:20:34 pm »
It would be a dormant configuration file, at least until it is called for.
Sgt.Blue
Reply #3 on:
January 04, 2015, 01:59:54 am »
Well does anyone know what it would do specifically? For instance, does it perhaps override the server.cfg or autoexec.cfg when the associated map is loaded?
bender180
Full Member
Reply #4 on:
January 04, 2015, 07:16:43 am »
if my memory on this is correct it lets a mapper change certain server variables such as gravity and what not for their specific map and not the whole server. an example of this I believe would be this map
http://steamcommunity.com/sharedfiles/filedetails/?id=131606096
which has near 0 gravity but it doesn't persist across the whole server.
General
Off-Topic
Map config files?
