Are you still considering all this or did you figure out what you wanted there? Also same as Jammin said, if you need a bit of help $$ with the start-up lemme know.
@ Jammin, your right about the wire to some degree, It does put a workout on the cpu for the server and will lower the fps if it gets too far for it. But it also tanks all the clients too due to some of the models. I should be getting in the new server today and I am working on a map to fix the vis problems. I was thinking about it when you were making a clock sorta thing about 2 weeks ago on freespace06. Every time I looked in that direction, no matter where I was on that map, I was getting 9 fps. I want the best of all kinds of builders to be able to build on the server so I am working on a new map just for that. It will have many different Vis zones to correct that problem. I might not have it all ironed out but I am working on it as much as I can. I'm gonna get the server server up and running right now to see if that helps at all.
Oh, I could add a bit more bandwidth (
boost), but I think that the 1.5 mb is enough for the ten players, I never really see it go over that and due to the map vis issues, most of the clients couldn't handle it if I went much over ten anyways.
Hmm, just checked boost and I might go for that anyways.
EDIT: Sorry guys I think I just posted where I probably wasn't supposed to. "Team Forum". Whoops
