Author Topic: Using Utime without the panel  (Read 4468 times)
Offline Nessaj
« on: January 10, 2015, 01:21:35 pm »
Hello guys,
I just want to ask if its possible to use Utime without the blue panel in the corner and which code I have to delete for that.
So it would be possible to see the players online time in the database for example as server owner :)
Re: Using Utime without the panel
« Reply #1 on: January 10, 2015, 01:58:19 pm »
"utime_enable 0" in your client console will disable the panel.
Offline Nessaj
« Reply #2 on: January 10, 2015, 03:19:42 pm »
Yes but I want to delete it for all persons on my server and not to give this possibility to the clients and I thinks this is just possible if I delete some code where you create this panel?
« Reply #3 on: January 10, 2015, 05:01:00 pm »
Hmm, doing a quick review of the code, I think if you delete cl_utime.lua, you'll forcibly disable the panel without causing any errors or functionality issues.
Offline Nessaj
« Reply #4 on: January 10, 2015, 05:20:09 pm »
Okay I will try this, thank you a lot Sir =)
