Set a usergroup as 'admin'
Topic: Set a usergroup as 'admin' (Read 6302 times)
[TS] mindfulhacker
January 25, 2015, 07:06:29 am »
I have multiple variations of my staff groups, eg Admin and Admin+.
However, those in Admin+ cannot use admin tools, such as FPP.
Is there any way to set my Admin+ group as 'admin', allowing the IsAdmin() to work?
Bytewave
Respected Community Member
Re: Set a usergroup as 'admin'
January 25, 2015, 08:06:57 am »
You'll probably want to look into your inheritance tree. From the sounds of things, you have that set up wrong.
[TS] mindfulhacker
Reply #2 on:
January 25, 2015, 08:22:07 am »
I don't believe I have done it wrong - It is exactly how I would like.
I have 2 'trees' of inheritance.
The Donator Tree:
superadmin - Inherits from HeadAdmin
HeadAdmin - Inherits from Admn+
Admin+ - Inherits from Moderator+
Moderator+ - Inherits from TrialMod+
TrialMod+ - Inherits from DiamondVIP
DiamondVIP - Inherits from PlatinumVIP
PlatinumVIP - Inherits from GoldVIP
GoldVIP - Inherits from SilverVIP
SilverVIP - Inherits from BronzeVIP
BronzeVIP - Inherits from user
And the Regular Tree:
Admin - Inherits from TrialMod
Moderator - Inherits from TrialMod
TrialMod - Inherits from user
user
This is so non-donor staff do not use the donator jobs, etc.
Bytewave
Reply #3 on:
January 25, 2015, 08:32:10 am »
Going loosely off
this FAQ thread
, forked inheritance trees usually cause problems with can_target. Seeing as none of the groups you've made inherit from admin or a group which inherits from admin... you aren't gonna get very far.
MrPresident
Ulysses Team Member
Reply #4 on:
January 25, 2015, 11:39:06 am »
for IsAdmin to work you need to inherit from Admin.
None of your groups inherits Admin so that's why it's not working.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #5 on:
January 25, 2015, 01:29:15 pm »
"Admin" is also not the same as "admin".
Lua is case sensitive.
MrPresident
Ulysses Team Member
Reply #6 on:
January 25, 2015, 04:04:40 pm »
This is true. Another reason why in general you should just keep all of your group names lowercase.
