Author Topic: Zombie Survival  (Read 23418 times)
Offline Avien
Zombie Survival
« on: April 11, 2007, 06:35:37 pm »
I was wondering how to make ULX work with Zombie Survival.  Anyone know?
Re: Zombie Survival
« Reply #1 on: April 11, 2007, 07:10:58 pm »
It doesn't work with it?
Offline Avien
Re: Zombie Survival
« Reply #2 on: April 11, 2007, 07:31:42 pm »
No.  The client menu does not work and all the commands and even ulx help does not work; votemap, ulx, ulx help, csay, etc.. nothing.  Only !noclip does work.
Not sure what is wrong.  Do i have to change a setting?
Re: Zombie Survival
« Reply #3 on: April 11, 2007, 08:18:14 pm »
It should work fine, the gamemode must be conflicting with it somehow. See if there's any errors in the console.
King [XeX]
Re: Zombie Survival
« Reply #4 on: April 12, 2007, 12:46:21 pm »
Earlier versions of ULX do work with ZS. Version 1 I believe.
Offline Avien
Re: Zombie Survival
« Reply #5 on: April 12, 2007, 01:19:53 pm »
I am using the newest ULX and ULib.  There are many errors that occur, such as nil values.  Do i have to remove addons?  Or should i just try reinstalling ULX and Ulib so there are no conflicting files?
I recently re-installed ULX and Ulib and nothing but only !noclip works.  Here is the list of errors i get when i enter the server and use !menu.  Mind you ulx help or anything like that does not work as well.  I also removed all addons but the default ones and nothing seems to fix it.
*ADDED*That message also shows up randomly when playing and everytime the map changes.  Anyone have any idea?*ADDED*
Warning: Unhandled usermessage 'ULib_autocomplete'
Warning: Unhandled usermessage 'ulx_autocomplete'
Warning: Unhandled usermessage 'ulx_map'
LC: Error running string:
LC: stdin:1: attempt to index global 'ulx' (a nil value)
[Admin]Avien: !menu
[Admin]Avien: !menu
Edit (spbogie): Merged double-post
« Last Edit: April 12, 2007, 06:18:57 pm by Avien »
Re: Zombie Survival
« Reply #6 on: April 13, 2007, 08:36:11 am »
Ah, I forgot that this gamemode uses script enforcer. You'll need to add all ULib/ULX clientside files to the file list for it to run. (It says this on the gamemode first post, specifically mentioning ULX :))
Offline Avien
Re: Zombie Survival
« Reply #7 on: April 13, 2007, 01:26:36 pm »
What do you mean by client-side files?  I am not sure what to do or change.
Re: Zombie Survival
« Reply #8 on: April 13, 2007, 05:08:24 pm »
Post on the ZS thread for instructions
Offline Avien
Re: Zombie Survival
« Reply #9 on: April 14, 2007, 08:38:16 am »
Well i posted in the ZS thread of the facepunch forums, and i was told to add files to the clientside.txt.  I did that but now i get a SendLua error.
http://forums.facepunchstudios.com/showthread.php?p=5211331#post5211331
Server is running Garry's Mod Version 24 - gamemode 'zombiesurvival'
Waiting for String Tables..
Lua initialized (Lua 5.1)
This server is running ULib version 2.03.
 => Sloppy Lua Warning:
 => SendLua("include("ULib/cl_init.lua")")
 => You're using SendLua to include a file.
ScriptEnforcer: Script ulx/cl_init.lua was not allowed to run!
 => SendLua("include("ULib/modules/ulx_init.lua")")
Hey 'avien' - You're in the 'superadmin' group on this server.
How do i fix that?
« Last Edit: April 14, 2007, 08:41:02 am by Avien »
Re: Zombie Survival
« Reply #10 on: April 14, 2007, 09:24:28 am »
ulx/cl_lib.lua was
That line (from your post) might be holding it up.
Offline Avien
Re: Zombie Survival
« Reply #11 on: April 14, 2007, 09:44:02 am »
YAY it works now!!
But what about the SendLua warning?  Anyway to fix that?
« Last Edit: April 14, 2007, 09:52:04 am by Avien »
Re: Zombie Survival
« Reply #12 on: April 14, 2007, 09:55:26 am »
No, it's another dumb garry trick. No way to fix it without a huge hack around.
Offline Avien
Re: Zombie Survival
« Reply #13 on: April 21, 2007, 12:56:09 pm »
Well a new version of the mode was released and i was told inorder to get rid of the sendlua warning i needed to add stuff to a AddCSLua file.  Anyone know what this is?
"The dedicated server needs to:"
* Have the file.
* Successfuly parse the file. (No errors)
* Have it in an AddCSLuaFile. (Probably not)
* Have it in clientscripts.txt
Re: Zombie Survival
« Reply #14 on: April 21, 2007, 01:12:41 pm »
That won't get rid of the warning, sorry.
