Author Topic: Help with ULX Command  (Read 5316 times)
Offline LegendProtocol
« on: January 28, 2015, 03:56:08 pm »
We currently have a command on our servers that allows us to place certain players on a watchlist. I was wondering how I would go about creating a watchid command, and what'd I have to change in the already existing print watchlist command. Below are the current watch, unwatch and watchlist commands as well as any related functions. I've tried making one myself based off the existing banid example but I haven't reached any success.
function ulx.watch(calling_ply, target_ply, reason)
target_ply:SetPData("Watched","true")
target_ply:SetPData("WatchReason",reason)
ulx.fancyLogAdmin( calling_ply, true, "#A marked #T as watched: "..reason.. "" , target_ply )
local watch = ulx.command("Essentials", "ulx watch", ulx.watch, "!watch",true)
watch:addParam{ type=ULib.cmds.PlayerArg }
watch:addParam{ type=ULib.cmds.StringArg, hint="reason", ULib.cmds.takeRestOfLine }
watch:defaultAccess( ULib.ACCESS_ADMIN )
watch:help( "Puts a player on watch list." )
function ulx.unwatch(calling_ply, target_ply)
target_ply:SetPData("Watched","false")
target_ply:RemovePData("WatchReason")
ulx.fancyLogAdmin( calling_ply, true, "#A removed #T from watch list", target_ply )
local unwatch = ulx.command("Essentials", "ulx unwatch", ulx.unwatch, "!unwatch",true)
unwatch:addParam{ type=ULib.cmds.PlayerArg }
unwatch:defaultAccess( ULib.ACCESS_ADMIN )
unwatch:help( "Removes a player from watch list." )
function userAuthed( ply, stid, unid )
if ply:GetPData("Watched") == "true" then
ulx.fancyLogAdmin(nil, true, "#T ("..stid.. ") is on the watchlist: "..ply:GetPData("WatchReason").. "",ply)
hook.Add( "PlayerAuthed", "watchlisthook", userAuthed )
function ulx.watchlist(calling_ply)
watchlist = {}
for k, v in pairs(player.GetAll()) do
if v:GetPData("Watched") == "true" then
table.insert( watchlist, v:Nick() or v:displayid())
table.insert(watchlist, v:GetPData("WatchReason"))
local watchstring = table.concat(  watchlist, ", " )
ulx.fancyLogAdmin( nil, true,  "Watchlist: #s ",watchstring )
local watchlist = ulx.command("Essentials", "ulx watchlist", ulx.watchlist, "!watchlist",true)
watchlist:defaultAccess( ULib.ACCESS_ADMIN )
watchlist:help( "Prints watch list." )
« Last Edit: January 28, 2015, 06:13:46 pm by LegendProtocol »
Re: Help with ULX Command
« Reply #1 on: January 28, 2015, 04:03:46 pm »
Since you don't have the player object to us, you'll need to use util.SetPData and GetPData. This means you can only accept SteamID (rather than IP or UniqueID).
« Reply #2 on: January 28, 2015, 04:28:23 pm »
Okay so this is what I have so far,
function ulx.watchid(calling_ply, target, reason)
if ULib.isValidSteamID(target) then
for k,v in pairs(player.GetAll()) do
if v:SteamID() == target then
ulx.watchid(calling_ply, v, reason)
return
target_ply:util.SetPData("Watched","true")
target_ply:util.SetPData("WatchReason",reason)
ULib.tsayError(calling_ply, "Invalid steamid.", true)
ulx.fancyLogAdmin( calling_ply, true, "#A marked #T as watched: "..reason.. "" , target )
local watchid = ulx.command("Essentials", "ulx watchid", ulx.watchid, "!watchid",true)
watchid:addParam{ type=ULib.cmds.StringArg, hint="steamid" }
watchid:addParam{ type=ULib.cmds.StringArg, hint="reason", ULib.cmds.takeRestOfLine }
watchid:defaultAccess( ULib.ACCESS_ADMIN )
watchid:help( "Puts a player on watch list via SteamID." )
Not sure where I would put getPData, I don't have much experience (I'm a complete newbie). :P
I know I'm doing something horribly wrong.
« Last Edit: January 28, 2015, 06:08:00 pm by LegendProtocol »
Offline lamb201
« Reply #3 on: January 31, 2015, 07:12:46 pm »
Hello.
util.SetPData & util.GetPData require a SteamID argument. (See: http://wiki.garrysmod.com/page/util/SetPData) So it would be like this:
  1. util.SetPData( steamID, name, value )
Also, i'm not quite sure what this is for?
  1. for k,v in pairs(player.GetAll()) do
  2.                                 if v:SteamID() == target then
  3.                                         ulx.watchid(calling_ply, v, reason)
  4.                                         return
  5.                                 end
  6.                         end
This is what I came up with, it is 3:10 am so I haven't tested it. Just trying to help :)
  1. function ulx.watchid( calling_ply, steamID, reason )
  2.
  3.         if not ULib.isValidSteamID( steamID ) then
  4.                 ULib.tsayError( calling_ply, "Invalid SteamID." )
  5.                 return
  6.         end
  7.
  8.         isWatched = util.GetPData( steamID, "Watched" ) or "false"
  9.         if isWatched == "true" then
  10.                 ULib.tsayError( calling_ply, "Player already being watched." )
  11.                 return
  12.         end
  13.
  14.         local playerEntity = false
  15.
  16.         for _, v in pairs( player.GetAll() ) do
  17.
  18.                 if v:SteamID() == steamID then
  19.                         playerEntity = v
  20.                 end
  21.
  22.         end
  23.
  24.         local name = steamID
  25.
  26.         if playerEntity ~= false then
  27.                 name = name .. " (" .. playerEntity:GetName() .. ")"
  28.         end
  29.
  30.         util.SetPData( steamID, "Watched", "true" )
  31.         util.SetPData( steamID, "WatchReason", reason )
  32.
  33.         ulx.fancyLogAdmin( calling_ply, true, "#A marked #T as watched (#s)", name, reason )
  34.
  35. end
  36. local watchid = ulx.command("Essentials", "ulx watchid", ulx.watchid, "!watchid", true)
  37. watchid:addParam{ type=ULib.cmds.StringArg, hint="steamid" }
  38. watchid:addParam{ type=ULib.cmds.StringArg, hint="reason", ULib.cmds.takeRestOfLine }
  39. watchid:defaultAccess( ULib.ACCESS_ADMIN )
  40. watchid:help( "Puts a player on watch list via SteamID." )
