Author Topic: No locaations to send to  (Read 6616 times)
Offline Tortoise
« on: January 30, 2015, 03:39:05 pm »
so i have a problem when i m using the bring command it dosnt save their location is there any way i can fix this?
Re: No locaations to send to
« Reply #1 on: January 30, 2015, 03:46:43 pm »
Is that the exact error message? Is there any error in game or server console?
It sounds like a conflicting addon is preventing it.
Additionally, make sure you're running latest ULib and ULX code from our GitHub repository.
Offline Tortoise
« Reply #2 on: January 30, 2015, 04:14:08 pm »
ill see the exact ms is (Command "ulx return", argument #1: you cannot target this person
) - this is the exact error msg
« Reply #3 on: January 30, 2015, 08:21:07 pm »
"cannot target" means your inheritance or can_target is set up so that literally, you can't target them.
It's not an error, it's an "access denied" on that person.
Offline Tortoise
« Reply #4 on: January 31, 2015, 08:38:54 am »
Im sorry i was tring to target my self and i set it so i cant this is the exact msg | (player) does not have any previous locations to send them to. |
im sorry for the wrong msg
« Reply #5 on: January 31, 2015, 09:06:38 am »
Are/have you used bring, teleport, goto or send before using "ulx return"?
When are you using return? Describe all actions from when you used bring, teleport, goto or send, up to point you try return.
Offline Tortoise
« Reply #6 on: January 31, 2015, 10:58:23 am »
i bring them to the place i want them then i try to return them i think it has to do with not saving their location before i bring them?
Offline Caustic Soda-Senpai
    • Steam Page
« Reply #7 on: January 31, 2015, 04:59:46 pm »
You just said you were only trying it on yourself, now you're saying that it was on other people.
If it's on yourself or anyone, they need to have been teleported FIRST.
If it's on someone ELSE make sure your inheritance is HIGHER so you can target them.
If you do not have access, make sure your rank can actually USE return.
Offline Tortoise
« Reply #8 on: January 31, 2015, 05:31:42 pm »
NO i was targeting players and whenever i bring them it works fine. But then i cant return them it says they have no previous locations
« Reply #9 on: February 01, 2015, 06:38:34 pm »
Copy and paste the console output from the chain of commands you're using the output.
Offline Tortoise
« Reply #10 on: February 02, 2015, 11:13:35 am »
Tortoise: !bring maj
You brought Majestic Manatee
Tortoise: !return maj
Majestic Manatee does not have any previous locations to send them to.
« Reply #11 on: February 02, 2015, 05:52:58 pm »
Do you receive any errors in the server console?
