Author Topic: "ulx help"or"ulx menu" dont work!  (Read 5978 times)
Finaldragon
« on: April 15, 2007, 01:56:18 am »
Hi,
I downloaded the installer with Ulib and Ulx and installed it to my gmod folder not on my dedicated then i started a server but when i type ulx help or anything other the console say the command dont exist...
can one help me?
Re: "ulx help"or"ulx menu" dont work!
« Reply #1 on: April 15, 2007, 07:18:48 am »
By default, the installer installs into your single player/Listen server folder.
If you have a dedicated server, you need to change the desitination folder during install to that of your root garrysmod dedicated server folder.
The installer has a popup window when you click close that in part states;
Quote from: ulx/ulib installer
"If you're not running a listen server, please see the readme in the garrysmod root for instruction on adding users"
Quote from: ulx_readme.txt
To install ULX, simply extract the files from the archive to your garrysmod folder.
When you've done this, you should have a file structure like this--
<garrysmod>/lua/ULib/modules/ulx_init.lua
<garrysmod>/lua/ulx/fun.lua
etc..
Note that installation for dedicated servers is EXACTLY the same!
Quote from: ulib_readme.txt
Please note that installation is the same on dedicated servers.
« Reply #2 on: April 15, 2007, 09:10:15 am »
