Author Topic: Permanent gag script question  (Read 4785 times)
Offline Jerpy
« on: February 08, 2015, 04:21:38 pm »
I found an old thread on here regarding a script for pgag which I have been searching for. I'm unable to find anything besides this one thread. It's about a year old and I did not want to bump it, so I have copied the script here. The last post on it was regarding something about how you should not have the script call the pdata that often, as it can have bad outcomes. He then said configure it so that it only is called when the player spawns. How would I go about doing that in this script?
    local CATEGORY_NAME = "GAG"
    function ulx.pgag( calling_ply, target_ply )
    local t = target_ply
    local PGagBool = tobool(t:GetPData("PGag")) or false
    if PGagBool then
    ULib.tsayError( calling_ply, t:Nick() .. " is already gagged!", true )
    return
    t:SetPData("PGag", true)
    ulx.fancyLogAdmin( calling_ply, "#A has permanently gagged #T", t )
    local pgag = ulx.command( CATEGORY_NAME, "ulx pgag", ulx.pgag, "!pgag" )
    pgag:addParam{ type=ULib.cmds.PlayerArg }
    pgag:addParam{ type=ULib.cmds.BoolArg, invisible=true }
    pgag:defaultAccess( ULib.ACCESS_ADMIN )
    pgag:help( "Permanently Gags target(s), disables microphone." )
    function ulx.pungag( calling_ply, target_ply )
    if not PGagBool then
    ULib.tsayError( calling_ply, t:Nick() .. " is not gagged!", true )
    return
    t:SetPData("PGag", false)
    ulx.fancyLogAdmin( calling_ply, "#A has permanently ungagged #T", t )
    local pungag = ulx.command( CATEGORY_NAME, "ulx pungag", ulx.pungag, "!pungag" )
    pungag:addParam{ type=ULib.cmds.PlayerArg }
    pungag:addParam{ type=ULib.cmds.BoolArg, invisible=true }
    pungag:defaultAccess( ULib.ACCESS_ADMIN )
    pungag:help( "Permanently ungags target(s), enables microphone." )
    local function doGag( listener, talker )
    local PGagBool = tobool(talker:GetPData("PGag")) or false
    if PGagBool then
    return false
    hook.Add( "PlayerCanHearPlayersVoice", "PGag", doGag )
Thanks in advance
Offline BobTheDuck69
Re: Permanent gag script question
« Reply #1 on: March 12, 2015, 11:38:57 am »
This is an up to date version i think.
function ulx.pgag( calling_ply, target_plys, should_unpgag )
if should_unpgag then
for k,v in pairs( target_plys ) do
v:RemovePData( "permgagged" )
ulx.fancyLogAdmin( calling_ply, "#A un-permagagged #T ", target_plys )
elseif ( not should_unpgag ) then
v:SetPData( "permgagged", "true" )
ulx.fancyLogAdmin( calling_ply, "#A permanently gagged #T", target_plys )
local pgag = ulx.command( "Custom", "ulx pgag", ulx.pgag, "!pgag" )
pgag:addParam{ type=ULib.cmds.PlayersArg }
pgag:help( "Gag target(s), disables microphone using pdata." )
pgag:setOpposite( "ulx unpgag", { _, _, true }, "!unpgag" )
local function pgagHook( listener, talker )
if talker:GetPData( "permgagged" ) == "true" then
return false
hook.Add( "PlayerCanHearPlayersVoice", "pdatagag", pgagHook )
---- functions to check if players are gagged upon them leaving and joining ----
function pgagPlayerDisconnect( ply )
if ply:GetPData( "permgagged" ) == "true" then
for k,v in pairs( player.GetAll() ) do
if v:IsAdmin() then
ULib.tsayError( v, ply:Nick() .. " has left the server and is permanently gagged." )
hook.Add( "PlayerDisconnected", "pgagdisconnect", pgagPlayerDisconnect )
function pgaguserAuthed( ply )
if v:IsAdmin() then
ULib.tsayError( v, ply:Nick() .. " has joined and is permanently gagged." )
hook.Add( "PlayerAuthed", "pgagauthed", pgaguserAuthed )
---- function to list players who are pgagged ----
function ulx.printpgags( calling_ply )
pgagged = {}
if v:GetPData( "permgagged" ) == "true" then -- find all players who have "gagged" set to true
table.insert( pgagged, v:Nick() )
local pgags = table.concat(  pgagged, ", " ) -- concatenate each player in the table with a comma
ulx.fancyLog( {calling_ply}, "PGagged: #s ", pgags ) -- only prints this to the player who called the function
local printpgags = ulx.command( "Custom", "ulx printpgags", ulx.printpgags, "!printpgags", true )
printpgags:defaultAccess( ULib.ACCESS_ADMIN )
printpgags:help( "Prints players who are pgagged." )
~The friendly neighborhood duckie~
