Author Topic: Turn up Jihad damage/radius?  (Read 6640 times)
Offline Remixful
« on: February 20, 2015, 10:01:01 pm »
if SERVER then
   AddCSLuaFile( "shared.lua" );
   resource.AddFile("sound/explode.wav");
   resource.AddFile("sound/siege/big_explosion.wav");
SWEP.HoldType                   = "slam"
if CLIENT then
   SWEP.PrintName                       = "Jihad"
   SWEP.Slot                            = 7
   SWEP.EquipMenuData = {
      type  = "item_weapon",
      name  = "Jihad Bomb",
      desc  = "Jihad bomb"
   SWEP.Icon = "VGUI/ttt/icon_c4"
 resource.AddFile("VGUI/ttt/icon_c4")
SWEP.Base = "weapon_tttbase"
SWEP.Kind = WEAPON_EQUIP
SWEP.CanBuy = {ROLE_TRAITOR}
SWEP.WeaponID = AMMO_C4
SWEP.ViewModel  = Model("models/weapons/v_c4.mdl")
SWEP.WorldModel = Model("models/weapons/w_c4.mdl")
resource.AddFile("models/weapons/v_c4.mdl")
resource.AddFile("models/weapons/w_c4.mdl")
SWEP.DrawCrosshair          = false
SWEP.ViewModelFlip          = false
SWEP.Primary.ClipSize       = -1
SWEP.Primary.DefaultClip    = -1
SWEP.Primary.Automatic      = false
SWEP.Primary.Ammo           = "none"
SWEP.Primary.Delay          = 5.0
SWEP.Secondary.ClipSize     = -1
SWEP.Secondary.DefaultClip  = -1
SWEP.Secondary.Automatic    = false
SWEP.Secondary.Ammo         = "none"
SWEP.NoSights               = true
function SWEP:Reload()
function SWEP:Initialize()
    util.PrecacheSound("siege/big_explosion.wav")
    util.PrecacheSound("explode.wav")
function SWEP:Think()
function SWEP:PrimaryAttack()
  self.Weapon:SetNextPrimaryFire(CurTime() + 2)
  local effectdata = EffectData()
  effectdata:SetOrigin( self.Owner:GetPos() )
  effectdata:SetNormal( self.Owner:GetPos() )
  effectdata:SetMagnitude( 1 )
  effectdata:SetScale( 1 )
  effectdata:SetRadius( 80 )
  util.Effect( "Sparks", effectdata )
  self.BaseClass.ShootEffects( self )
  -- The rest is only done on the server
  if (SERVER) then
    timer.Simple(2, function() self:Asplode() end )
    self.Owner:EmitSound( "explode.wav" )
function SWEP:Asplode()
  local k, v
  local ent = ents.Create( "env_explosion" )
  ent:SetPos( self.Owner:GetPos() )
  ent:SetOwner( self.Owner )
  ent:SetKeyValue( "iMagnitude", "125" )
  ent:Spawn()
  ent:Fire( "Explode", 0, 0 )
  ent:EmitSound( "siege/big_explosion.wav", 500, 500 )
  self:Remove()
function SWEP:SecondaryAttack()
  self.Weapon:SetNextSecondaryFire( CurTime() + 1.5 )
  local TauntSound = Sound( "taunt.wav" )
  self.Weapon:EmitSound( TauntSound )
How can I turn up the damage? I tried putting up imagnitude, i even tried 100,000 but then it didn't kill me but other players.
Offline Remixful
Re: Turn up Jihad damage/radius?
« Reply #1 on: February 20, 2015, 10:26:20 pm »
I think i found it:
  ent:SetKeyValue( "iRadiusOverride", 1000) // Setting the radius of the explosion
EDIT: I put it up really high like to 9999999 i was expecting everyone in the map to die.. so i guess this doesn't work.
« Last Edit: February 20, 2015, 10:28:11 pm by Remixful »
« Reply #2 on: February 21, 2015, 07:15:28 am »
  1. ent:SetKeyValue( "iMagnitude", "125" )
Change the second argument there.
Offline Remixful
« Reply #3 on: February 21, 2015, 04:18:27 pm »
« Reply #4 on: February 21, 2015, 04:26:56 pm »
Your edited line is different than the one I pointed out, otherwise I wouldn't have suggested it. Please don't just glance at the post.
Offline Remixful
« Reply #5 on: February 21, 2015, 04:32:13 pm »
I've tried setting 125 to different numbers and like I said, I even tried setting it to very high numbers, but then once I put it up to like 100,000 and some people died around me but I didn't die..
Offline Neku
« Reply #6 on: February 22, 2015, 12:56:01 am »
Did he not say in the first post that he had tried that already?  :P
« Last Edit: February 22, 2015, 12:59:25 am by Neku »
« Reply #7 on: February 22, 2015, 11:12:13 am »
I suppose he had, however his original post displayed a different line than the one I'd expected to see.
Either way, I'm pretty sure that ought to be the line. Maybe there's a cap or something, but I seem to remember that being the value you need to change to bump the blast radius.
