Author Topic: Using Evolve and ULX together (having problems with ranks)  (Read 5145 times)
Offline nex86
« on: March 05, 2015, 05:07:58 am »
On our server we're using ULX and evolve at the same time to have all required essentials for optimal control.
But the problem is, the ranks in ULX are getting messed up.
When someone is in the group "respected" or "regulars" they get moved back into the guest group after next server restart or rejoin.
Is there a workaround to fix this issue so that either one of the admin plugins won't override the ranks in ULX?
« Last Edit: March 05, 2015, 05:09:43 am by nex86 »
Re: Using Evolve and ULX together (having problems with ranks)
« Reply #1 on: March 05, 2015, 05:41:49 am »
Does the same name group exist in both admin mods, and,  do they both contain the same members?
I really don't recommend trying to run two admin mods just for this reason. They're likely going to over-ride each others custom group management hooks.
We definitely don't officially support it.
Offline nex86
« Reply #2 on: March 05, 2015, 08:27:27 pm »
yes the group names are all the same.
« Reply #3 on: March 05, 2015, 10:29:56 pm »
JamminR is right on the money here. You are definitely seeing conflicts between the two mods.
Instead of using two admin mods, why don't you try and get plugins for ULX to give you whatever functionality you have in Evolve that you feel you can't do without.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« Reply #4 on: March 06, 2015, 03:45:38 pm »
Evolve is only cool for it's chatbox that autofills, other than that it's very complicated.
