Author Topic: LuaLog  (Read 7299 times)
Offline Buzzkill
    • The Hundred Acre Bloodbath
LuaLog
« on: March 05, 2015, 09:32:28 am »
This is something I started working on yesterday, and is a mix of an actual need for me as well as my glorified "Hello World"  in Lua (everything I've done up until now in Lua has been done strictly within GMod).
This will parse srcds log files and insert them into a sqlite3 db. It provides some rudimentary config control, as well as supporting multiple servers on the same box.  Ultimately I envision building a query interface for it within GMod, and perhaps migrating the entire thing into GMod directly (which is why I chose to build it in Lua versus Python or even perl, for that matter).
I'm posting it because it's probably the first thing if any substance I can give back, and I'm posting it here because it's not ULX/Ulib dependent. I don't expect this to be of much value to anyone as-is, but perhaps some of the logic will be useful to someone under the right circumstances.  As it grows and becomes more solid it may attract more attention.
local driver = require "luasql.sqlite3"
-- user configuration --
local logDirs = {sbox1 = "/home/steam/sbox1/garrysmod/logs", jb1 = "/home/steam/jb1/garrysmod/logs", zs1 = "/home/steam/zs1/garrysmod/logs" };
local fileMask = "L*.log"
local ShouldArchiveFiles = true;
local targetDB = "/var/db/srcdslog.db"
local ShouldFlushDB = false;
local ShouldProcessLuaErrors = false;
local ShouldProcessRcon = false;
local ShouldProcessUnknown = true;
local ShouldProcessAdminSay = false; -- not yet implemented
local ShouldProcessPrivateSay = false; -- not yet implemented
-- psuedo enums --
-- Establish some positional info for matches
local LOGDT_START, LOGDT_END, LOGTM_START, LOGTM_END, LOGENTRY_START = 3,12, 16,23, 26
-- Establish internal logging types
local LOGTYPE_ERROR, LOGTYPE_WARNING, LOGTYPE_INFO, LOGTYPE_DEBUG  = 1,2,3,4
local LOGTYPEMSG = {"Error", "Warning", "Info", "Debug"}
-- Establish context types for srcds log entries
local LOGCONTEXT_UNKNOWN, LOGCONTEXT_SAY, LOGCONTEXT_CONNECT, LOGCONTEXT_VALIDATED, LOGCONTEXT_ENTERED, LOGCONTEXT_ULXCMD, LOGCONTEXT_RCON, LOGCONTEXT_BANID, LOGCONTEXT_LUAERROR, LOGCONTEXT_LUAERRORDETAIL, LOGCONTEXT_SAYTEAM, LOGCONTEXT_DISCONNECTED = 1,2,3,4,5,6,7,8,9,10,11,12
local LOGCONTEXTMSG = {"Unknown","Say", "Connected", "Validated", "Entered", "ULX Command", "RCON", "Ban", "Lua Error", "Lua Error Detail", "SayTeam", "Disconnected"}
-- Establish basic check pattents
local LOGCONTEXT_SICHECKS = {"say_team", "say", "connected, address", "STEAM USERID validated", "entered the game", "disconnected"}
local LOGCONTEXT_SICHECKID = {LOGCONTEXT_SAYTEAM, LOGCONTEXT_SAY,LOGCONTEXT_CONNECT, LOGCONTEXT_VALIDATED, LOGCONTEXT_ENTERED, LOGCONTEXT_DISCONNECTED}
-- Establish secondary checks
local LOGCONTEXT_NONSICHECKS = {"%[ULX%]","rcon from","Banid:", "Lua Error:"}
local LOGCONTEXT_NONSICHECKID = {LOGCONTEXT_ULXCMD, LOGCONTEXT_RCON, LOGCONTEXT_BANID, LOGCONTEXT_LUAERROR}
-- logging level
local ShowLogLevel = LOGTYPE_INFO
-- Misc globals --
local linesWritten = 0;
local ProcessingLuaError = false
local lastLuaErrorDate, lastLuaErrorTime = "",""
local currLogFileTag = ""
local currServer =""
local con, env
-- Some helper functions --
local function log(type, ...)
if (type == nil) then type = LOGTYPE_INFO end;
if (type > ShowLogLevel) then return end;
local printResult = LOGTYPEMSG[type] .. "\t"
for i,v in ipairs(arg) do
printResult = printResult .. tostring(v) .. "\t"
print (printResult);
local function DeleteExistingTag(logtag)
log(LOGTYPE_INFO,"Removing entries for "..currServer..logtag)
res = assert (con:execute(string.format([[DELETE from logs where logfile = '%s']], currServer..logtag)))
local function MoveFile(logfile)
os.rename(logfile, logfile..".archive")
function quotetrim(s)
  -- from PiL2 20.4
  s = s:gsub("^%s*(.-)%s*$", "%1")
  return (s:gsub("^\"*(.-)\"*$", "%1"))
local function IsLineValid(logline)
local t = string.match(logline, 'L %d%d/%d%d/%d%d%d%d [-] %d%d:%d%d:%d%d: ')
if (t == nil) then return false
else return true end
----- Main code
local function ProcessLineContext(logdt, logtm, logentry)
log (LOGTYPE_DEBUG, "Processing context: ", logentry);
local contextid = LOGCONTEXT_UNKNOWN
local nick, steamid, slot, ip, team, truelogentry = "","","","",""
local cmd1, cmd2 = "",""
-- Do basic checks for a standard steam info line plus context
nick, slot, steamid, team, truelogentry  = string.match(logentry, '"(.*)<(%d+)><(.+)><(.*)>" (.*)')
if (steamid ~= nil) then -- we have a typical Steam entry, like a say or a join
log(LOGTYPE_DEBUG, "Steam Info parse:", nick, steamid, slot, ip, team, contextid, truelogentry)
for key,value in pairs(LOGCONTEXT_SICHECKS) do
local part1, part2 = string.match(truelogentry, '^('..value..')(.*)')
if (part1 ~= nil) then
contextid = LOGCONTEXT_SICHECKID[key]
truelogentry = quotetrim(part2)
break
truelogentry = logentry -- default
nick, steamid, slot, ip, team = "","","","",""  -- clear them
log (LOGTYPE_DEBUG, "No Steam Info found", logentry)
-- There are other checks to do.
for key,value in pairs(LOGCONTEXT_NONSICHECKS) do
local part1 = string.match(truelogentry, '^('..value..')')
contextid = LOGCONTEXT_NONSICHECKID[key]
truelogentry = truelogentry
break
-- if we're processing lua error details out of bound and we get something other than unknown, turn off error processing
if (ProcessingLuaError and contextid ~= LOGCONTEXT_UNKNOWN) then
ProcessingLuaError = false;
-- if we encountered a lua error, prep to record future lines against it
if (contextid == LOGCONTEXT_LUAERROR and ShouldProcessLuaErrors) then
ProcessingLuaError = true;
lastLuaErrorDate = logdt
lastLuaErrorTime = logtm
-- we have an unknown line during lua error processing -- it's the stack.
if (contextid == LOGCONTEXT_UNKNOWN and ProcessingLuaError) then
contextid = LOGCONTEXT_LUAERRORDETAIL
if (contextid == LOGCONTEXT_RCON and ShouldProcessRcon == false) then
return
log(LOGTYPE_DEBUG,LOGCONTEXTMSG[contextid], nick, steamid, slot, ip, team, truelogentry)
if (contextid ~= LOGCONTEXT_UNKNOWN or ShouldProcessUnknown == true) then
linesWritten = linesWritten + 1
local logdatetime = logdt .. ' ' .. logtm
res = assert (con:execute(string.format([[INSERT INTO logs (server, logfile, logrowid, logdatetime, context, logentry, nick, steamid, ip, team)
VALUES ('%s','%s', %d, '%s', '%s', '%s', '%s', '%s','%s','%s')]], currServer, currServer..currLogFileTag,linesWritten, logdatetime,LOGCONTEXTMSG[contextid], con:escape(truelogentry), con:escape(nick), steamid, ip, team )))
local function ProcessLine(rownum, logline)
log (LOGTYPE_DEBUG, "Processing line # "..rownum, logline);
if (IsLineValid(logline)) then
local logdt = string.sub(logline,LOGDT_START,LOGDT_END)
local logtm = string.sub(logline,LOGTM_START,LOGTM_END)
local logentry = string.sub(logline,LOGENTRY_START)
if (ProcessingLuaError) then
ProcessLineContext(lastLuaErrorDate, lastLuaErrorTime, logline)
log (LOGTYPE_DEBUG, "Row number "..rownum.." rejected. Not a valid log entry");
local function ProcessFile(logfile)
log (nil, "Processing: "..logfile);
currLogFileTag = string.match(logfile, ".-([^\\/]-%.?[^%.\\/]*)$")
currLogFileTag = string.match(currLogFileTag,"([^%.]*)")
DeleteExistingTag(currLogFileTag)
lines = {}
    for line in io.lines(logfile) do
log(LOGTYPE_DEBUG, line)
lines[#lines+1] = line;
log(nil, "Lines loaded: "..#lines);
linesWritten = 0;
for key,logline in pairs(lines) do
ProcessLine(key, logline)
log(nil, "Lines written: "..linesWritten);
local function CheckAndCreateTable()
-- reset our table
if (ShouldFlushDB) then res = con:execute"DROP TABLE logs" end
res = assert (con:execute[[
CREATE TABLE IF NOT EXISTS logs(
server varchar(50),
logfile varchar(50),
logrowid int,
logdatetime datetime,
nick varchar(50),
steamid varchar(50),
slot int,
ip varchar(50),
context varchar(50),
team varchar(50),
logentry varchar(255)
-- Entry point --
env = assert (driver.sqlite3())
con = assert (env:connect(targetDB))
for key, value in pairs(logDirs) do
local filesToProcess = {}
dir = value
currServer = key
log (nil,"Building log file list")
local p = io.popen('find "'..dir..'" -type f -name "'..fileMask..'" | xargs ls -1tr')
for file in p:lines() do                         --Loop through all files
   filesToProcess[#filesToProcess + 1] = file;
   log (LOGTYPE_DEBUG, "Queued for processing: "..filesToProcess[#filesToProcess]);
for key,logfile in pairs(filesToProcess) do
-- don't archive the last file, it's most likely in use.
if next(filesToProcess,key) ~= nil and ShouldArchiveFiles == true then
MoveFile(logfile)
con:close()
env:close()
Offline Buzzkill
Re: LuaLog
« Reply #1 on: March 06, 2015, 08:46:48 am »
Question I'm going to throw out here based on this.
Using hooks instead of doing log analysis would be a much cleaner way. It would avoid a lot of the parsing nastiness. I chose to do log analysis versus event hooks for two reasons.  One, I don't have to worry about ancestor event handlers throwing an error and breaking the chain, and two, I can analyze lua error entries.  I can mitigate #1 by hooking to events with a low/read only priority (-20 or -19).  However, #2 still presents an issue.  There is no undocumented way to hook into lua error handlers, is there?
Thanks,
Mike
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
Re: LuaLog
« Reply #2 on: March 06, 2015, 07:44:33 pm »
I'm dyslexic, so maybe I didn't read something correctly, though because you have so much lines of code, I still didn't really entirely understand what your idea is here. So, you think you could reexplain it a bit, or give it a good overview on your ending goal of this project so others or maybe I could assist you?
Re: LuaLog
« Reply #3 on: March 06, 2015, 10:11:55 pm »
I'm guessing - yes.
One would have to find and see if the original lua error system in Gmod was done in lua (or, sadly in this case, it might be the lua compiler itself)
I've not researched how to look at all of Gmod lua code in quite some years. It used to be quite plainly visible.
If it WAS someway lua, well, it would be risky, but you'd over-ride it.
Just like we do in hook.Add (for adding priorities), you'd need to hook into original error output code.
Re: LuaLog
« Reply #4 on: March 07, 2015, 11:48:27 am »
Just a nitpick.
You don't need semicolons after lines in lua.
You CAN use them if you want, because they're simply ignored in lua.. but if you are going to use them at least be consistent.
  1. local logDirs = {sbox1 = "/home/steam/sbox1/garrysmod/logs", jb1 = "/home/steam/jb1/garrysmod/logs", zs1 = "/home/steam/zs1/garrysmod/logs" };
  2. local fileMask = "L*.log"
  3. local ShouldArchiveFiles = true;
  4. local targetDB = "/var/db/srcdslog.db"
  5. local ShouldFlushDB = false;
You have one on every other line here.
Offline Buzzkill
Re: LuaLog
« Reply #5 on: March 09, 2015, 06:35:43 am »
I know, I know.  :)  Too many languages and too much muscle memory.  My Java fingers still want to put a semicolon at the end of everything.
Right now it's simply a work in progress.  I had thrown it out there simply as some semi-interesting log parsing logic for anyone that might ever want to dissect it, but then I changed things up and actually asked a question (the Lua error hook).
Ultimately what I'm working towards is a db-based, multi-server logging system that can be accessed via the web to produce chat/error/event logs by day. The main point I'm waffling on is whether the parsing should be done completely outside of GMod (as I'm currently doing, which gives me cleaner access to errors as well as the ability to write to a centralized db), or if I should create wrapper hooks for everything within GMod and write the logs that way, which will unfortunately prevent me from seeing Lua errors and would make the centralized logging tricky if not impossible.
I'm guessing - yes.
Thanks.  Yes, I'm thinking it's the Lua compiler itself, given how pure the stack dump looks.
« Last Edit: March 09, 2015, 06:37:41 am by Buzzkill-THABB »
Re: LuaLog
« Reply #6 on: March 09, 2015, 12:10:28 pm »
I like your first idea, about making it outside of Garry's Mod, what a fantastic; and unique idea. As for your second idea, I'm not entirely sure if you are able to do that. I don't know if that's even possible, but you sound like you know more than I do, so good luck towards your project.
It would be interesting to see this project on release to everyone, or at least on codefodder (i think that's what it is called.)
Offline Buzzkill
Re: LuaLog
« Reply #7 on: March 30, 2015, 08:02:58 am »
I've been noodling this idea a little more, and keep coming back to the notion of multi-server (which was the original driver) *AND* multi-addon, which is rapidly becoming another hot-button issue for me.  I now have multiple addons on multiple servers that all produce interesting artifacts in terms of event information (ie, chat logs, Cake Anticheat flags, raw lua errors, etc).  It's becoming information overload and I'm losing insight.
So, in the spirit of BHAGS (big, hairy audacious goals), I'm rebranding LuaLog as the Grand Unifying Tracking System (GUTS), at least for now, with the goal of building a flexible programmatic interface so that it can hook into different systems (actual Gmod hooks, file patterns such as console and CAC logs, etc, etc).
Just an FYI... and my Cortez moment (ie, by announcing this in a somewhat public way, I'm less likely to cast it off when something shinier comes down the road).
Re: LuaLog
« Reply #8 on: March 30, 2015, 02:54:50 pm »
*drool*
SQUIRREL
* JamminR wipes corner of lip.
Offline Buzzkill
Re: LuaLog
« Reply #9 on: April 22, 2015, 12:44:01 pm »
This finally has a repo and I've published my current code.  It's currently strictly ULX logs, strictly Sqlite and very, very beta... but stay tuned.
https://github.com/THABBuzzkill/lualog
