Author Topic: Loading a random map when the server starts up  (Read 15199 times)
Offline Luk | twitch.tv/doctorluk
« on: March 05, 2015, 09:48:27 am »
Hello everyone :)
I'm having some - expected - problems with my TTT Server. As you all know GMod likes to crash once in a while and it's quite annoying if a map is being played many times because it's the server's default start map.
The start map is sometimes manually changed by me, but that is by far no permanent solution. I seek someone to create a script that randomly starts a map from the mappool on server start.
I've tried some LUA and made some progress but I'm not sure where to start and I'm also not sure whether there is a hook for the first server start.
Would be awesome if someone could help out :)
Host of Spielwiese der Erwachsenen, a German TTT Server for adults only.
Re: Loading a random map when the server starts up
« Reply #1 on: March 05, 2015, 06:28:23 pm »
I'm 98% sure you wouldn't be able to do this strictly in lua.
I was about to say not at all, then my mind started thinking 'well, perhaps a startup batch file could read from a gmod\data\<somefile> that contains a map randomly selected on startup for NEXT time', but, unless you wanted the server to start up, load command line/config file map, then restart loading a random map, you'd HAVE to have the command line outside of lua loading whatever randomly selected map.
So, 2 options I see.
100% outside lua.
Have server start non-lua startup script randomly pick from map in a list.
Using GLua and outside.
Server starts, picks random, writes it to a \data\ file for next startup.
Next server start, command line reads the map from that \data\ file.
Offline Tomzen
  • A new lua adventurer
    • Thirdage Gaming
« Reply #2 on: May 06, 2015, 10:16:54 pm »
100% outside lua.
Could you not use an array and then get a random value from the array and force the map to it? or even read the maps/ directory and pick a map random from the names (this would cause problems unless the maps are named like: (e.g) gm_flatgrass)
« Last Edit: May 06, 2015, 10:19:42 pm by Tomzen »
Finished:
Impersonate
WIP:
ServerMode <==
« Reply #3 on: May 07, 2015, 03:52:53 pm »
I worked on a game mode a while ago where if the server crashed, it would go back to the last map it was on.  This is entirely possible through Lua and data files.
Offline Timmy
  • Code monkey
« Reply #4 on: May 08, 2015, 12:34:43 am »
Would such system load the server on a default map, check if it crashed, then load the map it was originally on?
Edit: I'm asking cause I think maps are loaded before Lua is. You wouldn't be able to manipulate this without loading the server twice. Correct me if I'm wrong though. :)
« Last Edit: May 08, 2015, 12:50:54 am by Timmy »
« Reply #5 on: May 08, 2015, 07:53:38 am »
You are completely correct.  It is almost instant and hardly noticeable though.
« Reply #6 on: May 09, 2015, 08:10:36 am »
Additionally, you could use a (batch cmd or shell depending on the OS your server is running on) script to read from a file created while server is running normally.
« Reply #7 on: May 09, 2015, 01:54:54 pm »
Add a command to execute load_random_map.lua on your server shortcut/start-up script.
Offline Tomzen
    • Thirdage Gaming
« Reply #8 on: May 12, 2015, 05:15:33 pm »
This isn't quite what you want, but I've made this: /index.php/topic,8549.0.html#msg43938
You could easily convert it to do it on start up.
Finished:
Impersonate
WIP:
ServerMode <==
