Author Topic: After the new gmod update. Ulx menu doesn't work.  (Read 8190 times)
Offline Daley
« on: March 09, 2015, 04:01:45 am »
So here is the thing. All ulx commands still work but the menu won't open. If I set myself to a different rank I can open the menu and use the commands through it. But I cannot see give/see permissions to other usergroups. Also once you log-out I need to add myself to a different group again to be able to see the commands. I removed the user and the groups texts but they didn't fix anything. I also tried installing a new version of ulx. Also didn't work. Any help would be a appreciated!
Also there are no scripting errors at all.
Here are some pictures of how the ulx menu looks when I get it to work by the above method and when the permissions don't appear.
http://imgur.com/ppzxNVX,Ul1IyKz,LOIIWI0
Offline Luk | twitch.tv/doctorluk
Re: After the new gmod update. Ulx menu doesn't work.
« Reply #1 on: March 09, 2015, 04:23:31 am »
Same here, I guess we have to wait for an update to be made by the devs.
Host of Spielwiese der Erwachsenen, a German TTT Server for adults only.
Offline Daley
« Reply #2 on: March 09, 2015, 04:32:02 am »
Ah thank you for responding. At least it's not because I something up.
Offline M21z
« Reply #3 on: March 09, 2015, 05:04:22 am »
All ulx based commands are working except for ulx menu (xGui).
Offline Daley
« Reply #4 on: March 09, 2015, 05:22:50 am »
Perhaps this should be moved to the bug reports section. When I first posed this I was unsure if this had to do with ulx or with something I did wrong.
« Reply #5 on: March 09, 2015, 07:47:33 am »
This was a known issue on the Dev branch of Garry's Mod that I fixed two days ago. Updating to the latest version of ULX/ULib (XGUI v15.3.9) from our GitHub page should fix the problem.
See here for more info: https://github.com/Nayruden/Ulysses/issues/408
Offline Krapelex Crumb
« Reply #6 on: March 10, 2015, 01:39:38 pm »
Alright, thank you very much!
