Author Topic: Server auto disconnect  (Read 4460 times)
Offline Astro
« on: March 10, 2015, 08:55:36 am »
Hello,
I have a own server for Gmods (TTT). In the last time an error occurs and everybody gets the Waring : Auto Disconnect withthe timer and after a couple of seconds(Between 5-15) it disappears again and the server continues to run. The strange thing about it is that I don't get any kind of error message at all. Not from the game or in the log files.It appears that the Server is running normal.When I deinstall ulx then everything works .As far as I tested it I could not find out what exactly is producing it and it occur very irregular. I know it's not much of an Info but I hope you guys can maybe help me with it.Searching via google or in the Forums hasn't helped....
The Server is running on Linux and the resources are more than enough to handle Gmods.
Thanks,
Astro
« Last Edit: March 10, 2015, 11:50:14 am by Astro »
Re: Server auto disconnect
« Reply #1 on: March 10, 2015, 11:53:34 am »
I know of no functions in ULib or ULX that run on any timer that would cause issues like you see.
How did you determine it was related with no errors?
Where did you download ULib/ULX from?
Are you using any workshop items, did you disable those items?
Were you running in Sandbox, or another gamemode (which might be issue itself?)
Offline Astro
« Reply #2 on: March 10, 2015, 12:16:19 pm »
First thanks for the respond.
I downloaded it directly over SVN and exported it to my server.
I can't find any Error.I looked over ulx logs, the root server logs(in case it was a Connection Problem) and the console ingame. Nothing showed anything unusual. If you have an idea to look I will try it.The workshop items have all been diasabled and tried one by one and still the error occurs. When I deactiviate ulx/ulib it works for the longest time without a crash but i just detected that it can also occur. Now I'm wondering if it's really ulx/ulib.... Nevertheless maybe someone can still help me find the error
The gamemode is TTT.
