Author Topic: ULX Physgun freeze - FIXED - UPDATED  (Read 41148 times)
Offline Son_Of_Flynn
« on: March 12, 2015, 07:47:11 pm »
I used to have an add on for my server named ULX Physgun, it was made about 2 years ago and I can't even remember who coded it or where it was uploaded originally so sorry to whoever was the original coder, however the recent garry's mod updates as you all know messed with a few things so here is a fix .
Here is a list of the things I changed:
- SetNetworkedVar has been replaces with SetNWInt as it was removed in the latest gmod update.
- Players can longer suicide when physgun frozen.
- I'm not the original author, I'm reloading a fixed and improved version.
To install simply create a new .lua file in garrysmod/lua/autorun and call it something like: ULXPhysgun.lua and just simply paste the code in and restart your server.
It will work for any ULX group that can physgun players.
function FGod( ply, dmginfo )
if(ply:GetNWInt("FGod") == 1) then
dmginfo:ScaleDamage( 0 )
hook.Add("EntityTakeDamage", "FGod", FGod)
hook.Add("PhysgunDrop", "ply_physgunfreeze", function(pl, ent)
hook.Remove( "PhysgunDrop", "ulxPlayerDrop" )
ent._physgunned = false
if( ent:IsPlayer() ) then
ent:SetMoveType(pl:KeyDown(IN_ATTACK2) and MOVETYPE_NOCLIP or MOVETYPE_WALK)
if(pl:KeyDown(IN_ATTACK2)) then
ent:Freeze(true)
ent:SetNWInt("FGod", 1)
ent:DisallowSpawning( not should_unfreeze )
ulx.setNoDie( ent, not should_unfreeze )
table.insert( affected_plys, ent )
ent:Freeze(false)
ent:SetNWInt("FGod", 0)
ent:DisallowSpawning( false )
ulx.setNoDie( ent, should_unfreeze )
if SERVER then
if !ent:Alive() then
ent:Spawn()
self:PlayerSpawn(ent)
ent:SetPos(pl:GetEyeTrace().HitPos)
return --self.BaseClass:PhysgunDrop( pl , ent )
end)
hook.Add( "PhysgunPickup", "ply_physgunned", function(pl, ent)
ent._physgunned = true
end)
function playerDies( pl, weapon, killer )
if(pl._physgunned) then
return false
return true
hook.Add( "CanPlayerSuicide", "playerNoDeath", playerDies )
« Last Edit: March 17, 2015, 07:41:42 pm by Son_Of_Flynn »
Offline eagle9er9er
Re: ULX Physgun freeze - FIXED - UPDATED
« Reply #1 on: March 12, 2015, 08:59:51 pm »
I hope you don't hate me for asking a noob question, it's been awhile.
Where do I put this? I've been looking for a script like this forever, thank you.
Offline Stranger Danger
« Reply #2 on: March 13, 2015, 12:18:21 am »
You add it to Root/lua/autorun/server. I have a question, I wanted to modify it to where only admins can freeze and unfreeze targets, I tried adding ent:isAdmin() but ran into the problem that the target was getting stuck frozen and I couldn't unfreeze them. Is there any possible way you can modify it to where it only works with Admins? Much appreciated and very cool idea.
Offline lynx
« Reply #3 on: March 13, 2015, 02:20:35 am »
That'd be more a question for the Developer Chat forum, but heres your answer:
Where you have
If you add
and pl:IsAdmin()
To make it
if( ent:IsPlayer() and pl:IsAdmin() ) then
Then it would only run the freeze code if the player holding the other player is an admin. With ent:IsAdmin() it checks if the player being physgunned is an admin so it would return false all the time (unless they are an admin) causing it to not work.
To the OP, I do suggest creating it into an addon format rather than posting code and telling people to put it in autorun. The best way to do it (in my opinion) would be this:
Create a folder in addons called phys_freeze.
In phys_freeze make the following folder structure: /lua/ulx/modules/server/
Save the code into a file called phys_freeze.lua into the server folder.
Create a zip of the phys_freeze folder and upload it as an attachment to your original post.
« Last Edit: March 13, 2015, 02:24:11 am by lynx »
« Reply #4 on: March 13, 2015, 06:48:27 am »
I updated the main post with installation instructions.
« Reply #5 on: March 13, 2015, 07:04:29 am »
Where you have
If you add
and pl:IsAdmin()
To make it
You could also do:
pl:IsUserGroup("YOURUSERGROUP")
To only enable it for certain usergroups, however the group must be able to physgun players.
So in the end it will look like this:
if( ent:IsPlayer() and pl:IsUserGroup("example") ) then
« Reply #6 on: March 13, 2015, 10:52:22 am »
You could also do:
Perfect thanks, I didn't realize ent was the object being phys gunned. Thanks for the help and update.
« Last Edit: March 13, 2015, 11:02:48 am by Stranger Danger »
Offline silentkiller101
« Reply #7 on: March 15, 2015, 07:06:53 pm »
So this makes it so you can freeze players with the Physgun?
Offline aidanjohns921
« Reply #8 on: March 16, 2015, 02:09:40 pm »
Very nice script however my console likes to pop out this message whenever I physgun a player regardless of freezing or not (because of letting go is under the same function for unfreezing)
[ERROR] lua/autorun/ulxphysgun.lua:25: attempt to call method 'DisallowSpawning' (a nil value)
  1. fn - lua/autorun/ulxphysgun.lua:25
   2. unknown - addons/ulib/lua/ulib/shared/hook.lua:179
« Reply #9 on: March 17, 2015, 07:42:49 pm »
Thanks for this, it should be fixed now.
Offline pyro199931
« Reply #10 on: March 18, 2015, 09:00:25 pm »
Error in hook PhysgunDrop: lua/autorun/ulxphysgun.lua:25: attempt to call method 'DisallowSpawning' (a nil value)
stack traceback:
   lua/autorun/ulxphysgun.lua:25: in function 'fn'
   addons/ulib/lua/ulib/shared/hook.lua:179: in function <addons/ulib/lua/ulib/shared/hook.lua:162>
   [C]: in function '????????'
[ERROR]
  1. unknown - [C]:-1
lua error :|
Offline Livaco
    • Livaco
« Reply #11 on: March 27, 2015, 08:43:24 am »
It Doesent Appear, Heres The Code
  1. local CATEGORY_NAME = "Livaco"
  2.  function FGod( ply, dmginfo )
  3.                 if(ply:GetNWInt("FGod") == 1) then
  4.                                 dmginfo:ScaleDamage( 0 )
  5.                 end
  6. end
  7. hook.Add("EntityTakeDamage", "FGod", FGod)
  8.
  9. hook.Add("PhysgunDrop", "ply_physgunfreeze", function(pl, ent)
  10.         hook.Remove( "PhysgunDrop", "ulxPlayerDrop" )
  11.
  12.         ent._physgunned = false
  13.
  14.         if( ent:IsPlayer() ) then
  15.                 ent:SetMoveType(pl:KeyDown(IN_ATTACK2) and MOVETYPE_NOCLIP or MOVETYPE_WALK)
  16.
  17.                 if(pl:KeyDown(IN_ATTACK2)) then
  18.                         ent:Freeze(true)
  19.                         ent:SetNWInt("FGod", 1)
  20.                         ent:DisallowSpawning( not should_unfreeze )
  21.                         ulx.setNoDie( ent, not should_unfreeze )
  22.                         table.insert( affected_plys, ent )
  23.                 else
  24.                         ent:Freeze(false)
  25.                         ent:SetNWInt("FGod", 0)
  26.                         ent:DisallowSpawning( false )
  27.                         ulx.setNoDie( ent, should_unfreeze )
  28.                         table.insert( affected_plys, ent )
  29.                 end
  30.
  31.                 if SERVER then
  32.
  33.                         if !ent:Alive() then
  34.                                 ent:Spawn()
  35.                                 self:PlayerSpawn(ent)
  36.                                 ent:SetPos(pl:GetEyeTrace().HitPos)
  37.                         end
  38.                 end
  39.
  40.                 return --self.BaseClass:PhysgunDrop( pl , ent )
  41.         end
  42. end)
  43.
  44. hook.Add( "PhysgunPickup", "ply_physgunned", function(pl, ent)
  45.         ent._physgunned = true
  46. end)
  47.
  48. function playerDies( pl, weapon, killer )
  49.         if(pl._physgunned) then
  50.                 return false
  51.         else
  52.                 return true
  53.         end
  54. end
  55. hook.Add( "CanPlayerSuicide", "playerNoDeath", playerDies )
  56.
My Website
My Addons
PermaBanV1.0
Livaco Products©
Offline VirtualGames
« Reply #12 on: July 08, 2015, 10:52:12 pm »
Download?
« Reply #13 on: July 09, 2015, 01:25:47 am »
There's not a download. It's a code paste. He explains how to 'install' it if you read his post.
Offline Johnathan
« Reply #14 on: August 03, 2015, 09:51:27 am »
I get this Script Error when freezing somebody..
