Author Topic: Achatter admin chat *FIX*  (Read 5216 times)
Offline BobTheDuck69
« on: March 13, 2015, 05:01:05 pm »
First of all i need an admin to remove my old post second i dont know where to add the category for the command thats broken in startup
local seeachatterAccess = "ulx seeachatter"
if SERVER then ULib.ucl.registerAccess( seeachatterAccess, ULib.ACCESS_OPERATOR, "Ability to see 'ulx achatter'", "Other" ) end -- Give operators access to see achatters echoes by default
function ulx.achatter( calling_ply, message )
local format
local me = "/me "
if message:sub( 1, me:len() ) == me then
format = "(ADMINS) *** #P #s"
message = message:sub( me:len() + 1 )
format = " <Achatter> #P #s"
local players = player.GetAll()
for i=#players, 1, -1 do
local v = players[ i ]
if not ULib.ucl.query( v, seeachatterAccess ) and v ~= calling_ply then -- Calling player always gets to see the echo
table.remove( players, i )
ulx.fancyLog( players, format, calling_ply, message )
local achatter = ulx.command( CATEGORY_NAME, "ulx achatter", ulx.achatter, "!achatter", true, true )
achatter:addParam{ type=ULib.cmds.StringArg, hint="message", ULib.cmds.takeRestOfLine }
achatter:defaultAccess( ULib.ACCESS_ALL )
achatter:help( "Send a message to admins in the chat." )
~The friendly neighborhood duckie~
Re: Achatter admin chat *FIX*
« Reply #1 on: March 13, 2015, 10:19:49 pm »
Either define CATEGORY_NAME somewhere before it's called in command setup, or change it from a var to a string.
The error (which you didn't post) is pretty clear about that (nil)
Offline Livaco
    • Livaco
« Reply #2 on: March 27, 2015, 03:01:08 pm »
It Doesent Appear And I Did The Code
  1. local CATEGORY_NAME = "Livaco"
Heres The Entire Code Can Someone Fix It Plz
  2. function ulx.achatter( calling_ply, message )
  3.         local format
  4.         local me = "/me "
  5.         if message:sub( 1, me:len() ) == me then
  6.                 format = "(ADMINS) *** #P #s"
  7.                 message = message:sub( me:len() + 1 )
  8.         else
  9.                 format = " <Achatter> #P #s"
  10.         end
  11.
  12.         local players = player.GetAll()
  13.         for i=#players, 1, -1 do
  14.                 local v = players[ i ]
  15.                 if not ULib.ucl.query( v, seeachatterAccess ) and v ~= calling_ply then -- Calling player always gets to see the echo
  16.                         table.remove( players, i )
  17.                 end
  18.         end
  19.
  20.         ulx.fancyLog( players, format, calling_ply, message )
  21. end
  22. local achatter = ulx.command( CATEGORY_NAME, "ulx achatter", ulx.achatter, "!achatter", true, true )
  23. achatter:addParam{ type=ULib.cmds.StringArg, hint="message", ULib.cmds.takeRestOfLine }
  24. achatter:defaultAccess( ULib.ACCESS_ALL )
  25. achatter:help( "Send a message to admins in the chat." )
The Entire File Its In
  2. local waittime = 5 --Change this value for a differ in wait time after !cookie has been executed
  3.
  4. local lastusecookie = -waittime
  5.
  6. function ulx.cookie(calling_ply, target_plys, times)
  7.
  8.         if waittime + lastusecookie > CurTime() then
  9.
  10.                 ULib.tsayError(calling_ply, "Sorry, the cookie jar is empty! Please wait " .. waittime .. " seconds for it to fill up")
  11.
  12.         else
  13.
  14.                 ulx.fancyLogAdmin( calling_ply, "#A gave #T #i cookies!", target_plys, times )
  15.
  16.                 lastusecookie = CurTime()
  17.
  18.         end
  19.
  20. end
  21.
  22. local cookie = ulx.command( CATEGORY_NAME, "ulx cookie", ulx.cookie, "!cookie" )
  23.
  24. cookie:addParam{ type=ULib.cmds.PlayersArg }
  25.
  26. cookie:addParam{ type=ULib.cmds.NumArg, min=1, default=1, hint="times", ULib.cmds.optional, ULib.cmds.round }
  27.
  28. cookie:defaultAccess( ULib.ACCESS_ADMIN )
  29.
  30. cookie.help( "spread the love with cookies!" )
  31.
  32.
  33. local seeachatterAccess = "ulx seeachatter"
  34. if SERVER then ULib.ucl.registerAccess( seeachatterAccess, ULib.ACCESS_OPERATOR, "Ability to see 'ulx achatter'", "Other" ) end -- Give operators access to see achatters echoes by default
  35.
  36. local CATEGORY_NAME = "Livaco"
  37. function ulx.achatter( calling_ply, message )
  38.         local format
  39.         local me = "/me "
  40.         if message:sub( 1, me:len() ) == me then
  41.                 format = "(ADMINS) *** #P #s"
  42.                 message = message:sub( me:len() + 1 )
  43.         else
  44.                 format = " <Achatter> #P #s"
  45.         end
  46.
  47.         local players = player.GetAll()
  48.         for i=#players, 1, -1 do
  49.                 local v = players[ i ]
  50.                 if not ULib.ucl.query( v, seeachatterAccess ) and v ~= calling_ply then -- Calling player always gets to see the echo
  51.                         table.remove( players, i )
  52.                 end
  53.         end
  54.
  55.         ulx.fancyLog( players, format, calling_ply, message )
  56. end
  57. local achatter = ulx.command( CATEGORY_NAME, "ulx achatter", ulx.achatter, "!achatter", true, true )
  58. achatter:addParam{ type=ULib.cmds.StringArg, hint="message", ULib.cmds.takeRestOfLine }
  59. achatter:defaultAccess( ULib.ACCESS_ALL )
  60. achatter:help( "Send a message to admins in the chat." )
(ulx cookie not related)
« Last Edit: March 27, 2015, 03:03:38 pm by Livaco »
My Website
My Addons
PermaBanV1.0
Livaco Products©
Offline PwndKilled
« Reply #3 on: March 29, 2015, 07:46:46 am »
What are actually doing both
, true, true )
Offline Buzzkill
    • The Hundred Acre Bloodbath
« Reply #4 on: March 30, 2015, 07:45:50 am »
What doesn't appear, an error message? Might want to let the OP respond instead of jumping in and taking things potentially off course.  Alternatively, post a clear statement about the issue, any error messages and steps to reproduce.
FWIW, it looks very much like he copied your function call, but failed to include the CATEGORY_NAME var, which would of course throw a nil error.
Nvm -- I see now that you're responding to him with the solution (14 days later.....)
« Last Edit: March 30, 2015, 07:53:30 am by Buzzkill-THABB »
