Author Topic: Cloak  (Read 4556 times)
Offline Darkblizzard
Cloak
« on: March 14, 2015, 07:34:17 am »
Hello,
There seems to be an issue with my cloak. Whenever you cloak, your name above your head is still showing, whenever you have a physic gun out it reveals the brightness of it, and when you begin to type something it shows the message icon above your head.
How are you able to make it completely cloak so none of this happens?
The codes below.
function ulx.cloak( calling_ply, target_plys, amount, should_uncloak )
if not target_plys[ 1 ]:IsValid() then
Msg( "You are always invisible.\n" )
return
amount = 255 - amount
for i=1, #target_plys do
ULib.invisible( target_plys[ i ], not should_uncloak, amount )
if not should_uncloak then
ulx.fancyLogAdmin( calling_ply, "#A cloaked #T by amount #i", target_plys, amount )
ulx.fancyLogAdmin( calling_ply, "#A uncloaked #T", target_plys )
local cloak = ulx.command( CATEGORY_NAME, "ulx cloak", ulx.cloak, "!cloak" )
cloak:addParam{ type=ULib.cmds.PlayersArg, ULib.cmds.optional }
cloak:addParam{ type=ULib.cmds.NumArg, min=0, max=255, default=255, hint="amount", ULib.cmds.round, ULib.cmds.optional }
cloak:addParam{ type=ULib.cmds.BoolArg, invisible=true }
cloak:defaultAccess( ULib.ACCESS_ADMIN )
cloak:help( "Cloaks target(s)." )
cloak:setOpposite( "ulx uncloak", {_, _, _, true}, "!uncloak" )
Offline BobikHere
Re: Cloak
« Reply #1 on: March 14, 2015, 07:41:10 am »
If you use DarkRP , I'd suggest you to use the FAdmin Cloak.
Re: Cloak
« Reply #2 on: March 14, 2015, 07:58:10 am »
It is DarkRP, but I'm using ulx for the cloak. Not really sure about how to use the FAdmin Cloak.
I prefer to use ulx.
« Last Edit: March 14, 2015, 08:03:03 am by Darkblizzard »
Re: Cloak
« Reply #3 on: March 14, 2015, 10:41:30 am »
And fadmin often breaks ulx.
We often recommend NOT using Fadmin due to the conflicts.
It may be DarkRP breaks our cloak too. Give some time, perhaps we'll be able to look into it.
