Author Topic: Commands Use  (Read 6851 times)
Offline Darkblizzard
Commands Use
« on: March 18, 2015, 05:47:00 pm »
Hello,
I was wondering if there was a way where whenever you type a command such as "!ban lemon", it disappears and does the action?
Thank you.
Re: Commands Use
« Reply #1 on: March 18, 2015, 05:50:28 pm »
You mean that it doesn't echo to chat?
Re: Commands Use
« Reply #2 on: March 18, 2015, 05:52:21 pm »
I mean like not when it says "(Someone) did this to this (Player), not that. I mean just typing out the command regularly and it works, but it just stays in chat. I want it to disappear when the command is used.
Re: Commands Use
« Reply #3 on: March 18, 2015, 06:02:37 pm »
I believe he means not showing the "!slap" command in chat when he types it.  Remove the text so i doesn't show.  I don't believe this comes with ULX/ULib on default, but easy to change.  I've had to help someone with this before.
In file <gmod folder>/addons/ulib/lua/ulib/server/concommand.lua change line 68 to this:
return ""
So the whole function will look like this:
local function sayCmdCheck( ply, strText, bTeam )
local match
for str, data in pairs( ULib.sayCmds ) do
local str2 = str
if strText:len() < str:len() then -- Go ahead and allow commands w/o spaces
str2 = string.Trim( str )
if strText:sub( 1, str2:len() ):lower() == str2 then
if not match or match:len() <= str:len() then -- Don't rematch if there's a more specific one already.
match = str
if match then -- We've got a winner!
local data = ULib.sayCmds[ match ]
local args = string.Trim( strText:sub( match:len() + 1 ) ) -- Strip the caller command out
local argv = ULib.splitArgs( args )
-- ULib command callback
if data.__cmd then
local return_value = hook.Call( ULib.HOOK_COMMAND_CALLED, _, ply, data.__cmd, argv )
if return_value == false then
return nil
if not ULib.ucl.query( ply, data.access ) then
ULib.tsay( ply, "You do not have access to this command, " .. ply:Nick() .. "." )
-- Print their name to intimidate them :)
return "" -- Block from appearing
local fn = data.fn
local hide = data.hide
ULib.pcallError( fn, ply, match:Trim(), argv, args )
return ""
return nil
« Last Edit: March 18, 2015, 06:04:18 pm by Aaron113 »
Re: Commands Use
« Reply #4 on: March 18, 2015, 06:43:03 pm »
Thank you!
Offline Professor_Smiley
Re: Commands Use
« Reply #5 on: April 06, 2015, 06:29:56 am »
no problem
Re: Commands Use
« Reply #7 on: April 06, 2015, 09:14:37 am »
This does of course require permissions be set for !hide, and may allow admins to run other commands in a hidden manner that you might find undesirable, which might require some mods to Custom Commands.
The !hide command still makes the player (admin) run the command, so ULX/ULib kicks in with permissions either way. All !hide really does is temporarily get logecho to 0 and then back to what it was after the command has been run.
Offline Buzzkill
    • The Hundred Acre Bloodbath
Re: Commands Use
« Reply #8 on: April 06, 2015, 09:32:23 am »
I meant that if he wanted (for example), slay to be usable through !hide, but kick to NOT be useable through hide, then some configuration/coding might be necessary.  I understand that the underlying permissions for slay and kick are still applied.
Hide doesn't just toggle logecho -- it also suppresses the command's presence in chat, which is what I believe the OP was looking for.
Never mind -- I'm being daft.
Re: Commands Use
« Reply #9 on: April 06, 2015, 09:59:55 am »
Ah, I misunderstood. Yes, that would essentially be a problem.
