Author Topic: Store Player Info in Database  (Read 4468 times)
Offline bigbadbeee
« on: March 22, 2015, 01:22:14 pm »
here is my code
require( "mysqloo" )
DB_HOST = "localhost"
DB_PORT = 3306
DB_NAME = "badminmod"
DB_USERNAME = "root"
DB_PASSWORD = ""
function connectToDatabase()
databaseObject = mysqloo.connect(DB_HOST, DB_USERNAME, DB_PASSWORD, DB_NAME, DB_PORT)
databaseObject.onConnected = function() print("Connected to Database") end
databaseObject.onConnectionFailed = function() print("Database could not be found") end
connectToDatabase()
function checkQuery(query)
local playerInfo = query:getData()
if playerInfo[1] ~= nil then
return true
return false
function FirstJoinMysql( ply )
local query1 = databaseObject:query("SELECT * FROM bam_players WHERE ID = '" .. ply:SteamID() .. "'")
query1.onSuccess = function(q)
if not checkQuery(q) then
local query2 = databaseObject:query("INSERT INTO bam_players(ID, Name) VALUES ('" .. ply:SteamID() .. "'," .. ply:SteamName() .. ")")
query2.onSuccess = function(q) print("Your Info Was Stored") end
query2.onError = function(q,e) print("Your Info Was Not Stored") end
query2.start()
print("You are already created")
 query1.OnError = function(q,e) print("Failed") end
 query1.start()
hook.Add( "PlayerInitialSpawn", "PlayerInitialSpawn", FirstJoinMysql )
I get this error
[ERROR] addons/badminmod/lua/autorun/server/bam.lua:40: attempt to index local 'query1' <a nil value>
1. v - addons/badminmod/lua/autorun/server/bam.lua:40
 2. unknown - lua/includes/modules/hook.lua:84
What Iam I doing wrong?
Re: Store Player Info in Database
« Reply #1 on: March 22, 2015, 01:34:59 pm »
Well, for starters... if you're using MySQLOO, it's:
query1:onError
query1:onSuccess
query1:start()
you also need to run databaseObject:connect() inside of your connection function.
Please look and see if you can find the post I've made here for using MySQL to do user authentication. That should have a working example of connecting to a database and doing queries.
Offline bigbadbeee
« Reply #2 on: March 22, 2015, 01:47:02 pm »
Thank I will try it and Try to find your post
