Author Topic: Quick question on file.Append  (Read 5811 times)
Offline Zmaster
« on: March 23, 2015, 02:27:49 pm »
I'm starting to create my own heavy logging system, but there's this one part I could never figure out
I'm starting simple (chat logs)
The logging part is working fine and all, but I can not for the life of me figure out how to put each new addition to the data file on a new line
I tried putting \n into the file.Append string but that wouldn't change what ended up in the code for whatever reason
This is how I'm editing the file right now
file.Append("chatlogs/"..curdate..".txt", newline.."\n")
Re: Quick question on file.Append
« Reply #1 on: March 23, 2015, 02:30:05 pm »
How are you viewing the file created by your script? Windows Notepad?
Either try a different text editor, or use \r\n as a new line escape sequence.
Offline Zmaster
« Reply #2 on: March 23, 2015, 02:43:26 pm »
Yep, that would be it
Just checked it in Notepad++ and it shows on different lines there
Now I have even more reason to never use Notepad
Thanks for the quick response, Bytewave
