Author Topic: AWarn Doesent Work?  (Read 18923 times)
Offline Livaco
    • Livaco
AWarn Doesent Work?
« on: March 24, 2015, 02:35:03 pm »
Fixed NO Longer Needed
« Last Edit: April 02, 2015, 04:23:06 am by Livaco »
My Website
My Addons
PermaBanV1.0
Livaco Products©
Offline Caustic Soda-Senpai
    • Steam Page
Re: AWarn Doesent Work?
« Reply #1 on: March 24, 2015, 05:15:31 pm »
I'm going to ask the obvious question: Did you restart your server?
Offline Livaco
    • Livaco
« Reply #2 on: March 24, 2015, 05:22:16 pm »
Yes I typed in the console restart
My Website
My Addons
PermaBanV1.0
Livaco Products©
« Reply #3 on: March 24, 2015, 05:46:14 pm »
It doesn't work in Single Player.
The error in your console indicates that you tested this in SinglePlayer.
You need to run this on a server for it to work.
Offline Livaco
    • Livaco
« Reply #4 on: March 25, 2015, 12:55:36 am »
I've got the minge bots addon and I'm spawning them in on a local
My Website
My Addons
PermaBanV1.0
Livaco Products©
    • Steam Page
« Reply #5 on: March 25, 2015, 01:03:43 am »
Spawning bots in singleplayer doesn't cut it.
Offline Livaco
    • Livaco
« Reply #6 on: March 25, 2015, 01:12:54 am »
no its a local server im trying it on -_-
My Website
My Addons
PermaBanV1.0
Livaco Products©
Offline Livaco
    • Livaco
« Reply #7 on: March 25, 2015, 01:14:19 am »
If U Need I Can Give U The Code
« Last Edit: March 25, 2015, 01:37:50 am by Livaco »
My Website
My Addons
PermaBanV1.0
Livaco Products©
« Reply #8 on: March 25, 2015, 11:14:47 am »
I'm more interested in any error messages you get. Paste here anything from your console after you try to issue a warning.
Offline Livaco
    • Livaco
« Reply #9 on: March 26, 2015, 05:38:45 am »
Heres The Consle Code
Initial walk and run speeds fetched.
Walk Speed: 250
Run Speed: 500
[Aid15 :)|2|STEAM_0:0:56797092] Lua Error:
[ERROR] addons/ulx/lua/ulx/modules/sh/chat.lua:306: unexpected symbol near '2.'
  1. unknown - addons/ulx/lua/ulx/modules/sh/chat.lua:0
Spawning textscreens...
DLL_MessageEnd:  Refusing to send user message TextMsg of 256 bytes to client, user message size limit is 255 bytes
Requesting texture value from var "$basetexture" which is not a texture value (material: trails/tube)
] bot
Player Bot01 has joined the game
Client "Bot01" spawned in server (BOT)<BOT>.
Requesting texture value from var "$basetexture" which is not a texture value (material: pp/copy)
« Last Edit: March 26, 2015, 05:40:22 am by Livaco »
My Website
My Addons
PermaBanV1.0
Livaco Products©
    • Steam Page
« Reply #10 on: March 26, 2015, 01:16:30 pm »
That is an error that needs to be fixed...
« Reply #11 on: March 26, 2015, 03:04:53 pm »
Nothing in that is related to AWarn.
    • Steam Page
« Reply #12 on: March 26, 2015, 05:06:44 pm »
I'm aware that it's not related to AWarn, I'm stating its an error that needs to be fixed. I should have specified that it was an error not related to AWarn.
« Reply #13 on: March 26, 2015, 10:12:36 pm »
and I was responding to Livaco's post, not yours. He created this thread to try and get me to help him 'fix' AWarn2 on his server, but has yet to produce any kind of information to allow me to do so.
Offline Livaco
    • Livaco
« Reply #14 on: March 27, 2015, 01:35:51 am »
Heres The Code Of awarn_sqlite.lua, If U Need More Just Tell Me
local PlayerMeta = FindMetaTable("Player")
function awarn_tbl_exist()
if sql.TableExists("awarn_warnings") then
ServerLog( "AWarn: Warning Table Exists\n" )
local query = "CREATE TABLE awarn_warnings ( pid INTEGER PRIMARY KEY AUTOINCREMENT, unique_id varchar(255), admin varchar(255), reason text, date varchar(255) )"
result = sql.Query(query)
ServerLog( "AWarn: Creating Warning Table...\n" )
ServerLog( "AWarn: Warning Table created sucessfully.\n" )
ServerLog( "AWarn: Trouble creating the Warning Table\n" )
ServerLog( "AWarn: " .. sql.LastError( result ).."\n" )
if sql.TableExists("awarn_playerdata") then
ServerLog( "AWarn: Player Data Table Exists\n" )
local query = "CREATE TABLE awarn_playerdata ( unique_id varchar(255), warnings INTEGER, lastwarn varchar(255) )"
ServerLog( "AWarn: Creating Player Data Table...\n" )
ServerLog( "AWarn: Player Data Table created sucessfully.\n" )
ServerLog( "AWarn: Trouble creating the Player Data Table\n" )
ServerLog( "AWarn: " .. sql.LastError( result ).. "\n" )
if sql.TableExists("awarn_serverdata") then
ServerLog( "AWarn: Server Data Table Exists\n" )
local query = "CREATE TABLE awarn_serverdata ( key TEXT, val INTEGER )"
ServerLog( "AWarn: Creating Server Data Table...\n" )
ServerLog( "AWarn: Server Data Table created sucessfully.\n" )
ServerLog( "AWarn: Trouble creating the Server Data Table\n" )
function awarn_reloadtables()
local query = "DROP TABLE awarn_warnings"
local query = "DROP TABLE awarn_playerdata"
awarn_tbl_exist()
function awarn_saveservervalue( key, val )
--print( key .. " " .. val )
local query = "SELECT * FROM awarn_serverdata WHERE key='" .. key .. "'"
result = sql.QueryRow(query)
--PrintTable(result)
if not result then
local query = "INSERT INTO awarn_serverdata VALUES ( '" ..key.. "', '" .. val .. "' )"
SetGlobalInt( key, val )
net.Start("AWarnChatMessage") net.WriteTable({ Color(60,60,60), "[", Color(30,90,150), "AWarn", Color(60,60,60), "] ", Color(255,255,255), "Value ", Color(0,0,0), "(" .. key .. ") ", Color(255,255,255), "has been set to ", Color(0,0,0), "(" .. val .. ")" }) net.Broadcast()
if not result then
ServerLog( "AWarn: Server Setting (" .. key .. ") set to " .. val .. "\n")
ServerLog( "AWarn: Problem setting value for (" .. key .. ")\n")
local query = "UPDATE awarn_serverdata SET val='" .. val .. "' WHERE key='" ..key.. "'"
if not result then
function awarn_setserverdefaultvalues()
for k, v in pairs( AWarn.DefaultValues ) do
local query = "SELECT * FROM awarn_serverdata WHERE key='" .. k .. "'"
if result then
awarn_saveservervalue( k, result.val )
awarn_saveservervalue( k, v )
hook.Add( "InitPostEntity", "AWarn_SetServerDefaults", awarn_setserverdefaultvalues )
function awarn_addwarning( uid, reason, admin )
reason = sql.SQLStr( reason )
admin = sql.SQLStr( admin )
date = os.date()
local query = "INSERT INTO awarn_warnings VALUES (NULL, '" ..uid.. "', " ..admin.. ", " ..reason.. ", '" ..date.. "')"
--print(query)
function awarn_incwarnings( ply )
local uid = ply:SteamID64()
local query = "SELECT warnings FROM awarn_playerdata WHERE unique_id='" .. uid .. "'"
local wnum = 0
if not result then
wnum = 1
local query = "INSERT INTO awarn_playerdata VALUES ( '" ..uid.. "', '" .. wnum .. "', '" .. os.time() .."' )"
wnum = tonumber(result.warnings) + 1
local query = "UPDATE awarn_playerdata SET warnings='" .. wnum .. "', lastwarn='" .. os.time() .."' WHERE unique_id='" ..uid.. "'"
awarn_checkkickban( ply )
awarn_decaywarns( ply )
function awarn_incwarningsid( uid )
local wnum = 0
if not result then
wnum = 1
function awarn_decwarnings( ply, admin )
local wnum = 0
if not result then
if admin then AWSendMessage(admin, "AWarn: This player has no warnings on record") end
if tonumber(result.warnings) > 0 then
wnum = tonumber(result.warnings) - 1
            AWSendMessage( admin, "AWarn: Reduced " .. ply:Nick() .. "'s active warnings by 1!")
if admin then AWSendMessage(admin, "AWarn: This player has 0 active warnings already") end
function awarn_decwarningsid( uid, admin )
local wnum = 0
if not result then
            AWSendMessage( admin, "AWarn: Reduced " .. tostring(uid) .. "'s active warnings by 1!")
function awarn_setwarnings( ply, num )
local wnum = 0
if not result then
local query = "INSERT INTO awarn_playerdata VALUES ( '" ..uid.. "', '" .. num .. "', '" .. os.time() .."' )"
local query = "UPDATE awarn_playerdata SET warnings='" .. num .. "' WHERE unique_id='" ..uid.. "'"
function awarn_delwarnings( ply, admin )
if not result then
local query = "DELETE FROM awarn_playerdata WHERE unique_id='" ..uid.. "'"
local query = "DELETE FROM awarn_warnings WHERE unique_id='" ..uid.. "'"
AWSendMessage(admin, "AWarn: Cleared all warnings for player: " .. ply:Nick() )
if not result then
function awarn_delwarningsid( uid, admin )
if not result then
AWSendMessage(admin, "AWarn: Cleared all warnings for player: " .. tostring(uid) )
function awarn_delsinglewarning( admin, warningid )
local query = "SELECT * FROM awarn_warnings WHERE pid=" .. warningid
if not result then
AWSendMessage(admin, "AWarn: Record for this warning ID not found")
return
local query = "DELETE FROM awarn_warnings WHERE pid=" .. warningid
result = sql.Query( query )
function awarn_getwarnings( ply )
local wnum = 0
if not result then
wnum = 0
wnum = result.warnings
return tonumber(wnum)
function awarn_getlastwarn( ply )
local query = "SELECT lastwarn FROM awarn_playerdata WHERE unique_id='" .. uid .. "'"
local lastwarn = "NONE"
if not result then
lastwarn = "NONE"
lastwarn = result.lastwarn
return tostring(lastwarn)
function awarn_sendwarnings( ply, target_ply )
local uid = target_ply:SteamID64()
local warns = awarn_getwarnings( target_ply )
local query = "SELECT * FROM awarn_warnings WHERE unique_id='" .. uid .. "'"
--print(warns)
if result then
net.Start("SendPlayerWarns")
net.WriteTable( result )
net.WriteInt( warns, 32 )
net.Send( ply )
result = {}
net.Send( ply )
function awarn_gettotalwarnings( ply )
if result then
return #result
return 0
function awarn_sendownwarnings( ply, target_ply )
local warns = awarn_getwarnings( ply )
--print(warns)
if result then
net.Start("SendOwnWarns")
net.Send( ply )
result = {}
net.Send( ply )
My Website
My Addons
PermaBanV1.0
Livaco Products©
